#21 |
I had exactly the same issue with my blown 8BA. The original one from B&M was not a tight fit on the crank and over time it destroyed the keyway on the pulley. I had a new one machined from aircraft grade aluminum that was a semi-pressed fit. Cost was $325.00..
#22 | |
![]() Quote:
![]() Sent from my SM-N986U using Tapatalk |
#23 |
Can you cut off the old pulley and use it with the new adapter?
#24 |
How about something like this? The sheaves and bushings come in many sizes.
You could get a smaller bushing and have it bored to your shaft size. https://www.ebay.com/itm/39228101691...id=20029977905 |
#25 |
You can broach a key way in the sleeve with a press.
Bruce
Works good Lasts long time |
#26 |
#27 | |
![]() Quote:
