09-19-2021, 03:28 AM | #21 |
Re: hoky fixs
That’s a “bit” dangerous
09-20-2021, 08:20 AM | #22 |
Re: hoky fixs
My RPU had a total of 12 rear spring leaves, and they improvised shims for the clamps.
09-20-2021, 08:46 AM | #23 |
Re: hoky fixs
Removed the gas gauge and found a Christmas tree light bulb used as a float.
09-20-2021, 08:57 AM | #24 |
Re: hoky fixs
Black pepper flakes in the radiator to stop a small leak….
09-20-2021, 09:34 AM | #25 |
Re: hoky fixs
09-20-2021, 09:58 AM | #26 |
Re: hoky fixs
09-20-2021, 10:06 AM | #27 |
Re: hoky fixs
09-20-2021, 11:26 AM | #28 |
Re: hoky fixs
09-20-2021, 03:58 PM | #29 |
Re: hoky fixs
All the hinges on all four doors were welded to the body, guess the P.O. got tired of adjusting the doors.
Took me several weeks to get them all back to "normal"
09-23-2021, 05:02 PM | #30 |
Re: hoky fixs
02-13-2022, 02:06 PM | #31 |
Re: hoky fixs
quote. "i just rebuilt my distributor but i cant keep the points set and it has a bit of a miss"
this is the distributor shaft that i took out. A guy wouldn't want to spend $20 on new shafts and bushings. lol
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
02-13-2022, 05:39 PM | #32 |
Re: hoky fixs
On my roadster the one of the owners spent $$$ on it for stone guard, hydraulic brake conversion, things like that, but kingpins ,brake and clutch pedal shaft steering balls, etc never rebuilt.Also the “why buy bolts when we have a welder”like a previous post .Also when the rear hubs were fitted must have seen the bearings in hub and thought they were similar to front bearings backed off two slots on rear axle nuts. Lack basic Model A knowledge .
02-13-2022, 05:48 PM | #33 |
Re: hoky fixs
My Model-A wasn't too bad, but I bought it pretty much in pieces. My 36 Plymouth streetrod has been a different story. The battery was relocated to the trunk. The positive cable is two pieces of welder cable, sliced together with a slit bolt, and taped. But here's the ting, they drilled a hole in the sheet metal side panel of the trunk, and instead of a grommet they put s\a piece of duct tape around the opening.
I won't tell you the stunt the pulled with the cooling fan for the engine. The engine was in my A when I got it, but the timing was set backwards of what is correct. Push the handle up to go down the road. Needless to say the timing was off. LOL LOL LOL |
02-14-2022, 08:23 AM | #34 |
Re: hoky fixs
If you can still find it, Jim Mason's old web page has a section of "messtorations" complete with photos.
Amusing and sometimes scary to see.
our next Model A is out there in the unknown...... |
02-14-2022, 05:10 PM | #35 | |
Re: hoky fixs
This one?? http://jmodela.coffeecup.com/mess.html |
02-14-2022, 05:37 PM | #36 |
Re: hoky fixs
som nice fixs thar
02-17-2022, 05:18 AM | #37 |
Re: hoky fixs
I have have two "restored A's ??" and have found on both these cars that the PO's had left out the small felt seal that fits between the bottom of the King Pin and the Backing Plate . The result being that each time the King Pins were greased the front hubs got a good shot of grease. Did nothing for braking. One of these cars was restored by a professional restorer. Makes you wonder. Happy motoring. Dave.
02-17-2022, 10:51 AM | #38 |
Re: hoky fixs
This is one that comes to mind, no cotter pins available I guess.
02-17-2022, 11:02 AM | #39 | |
Re: hoky fixs
hey now. I've actually done that. lol
02-17-2022, 01:14 PM | #40 |
Re: hoky fixs
I always thought they were called "farmers fixes" some are really inventive!
Gene USN |
