Old 07-13-2021, 03:53 AM   #1
chrs1961815
chrs1961815's Avatar
Default Re: FRONT model A ‘modern’ seal use.
I would only go with 1 piece pulleys - it seems the 2 piece pulleys coming apart is a real problem.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-15-2021, 11:51 PM   #2
Oldcarbearings
Location: North Warrandyte, Melbourne,Victoria, Australia
If available i'd use a metal cased leather or combination felt wiper/leather lip spring loaded oil seal as both the felt&leather material are kinder to older style lubricants&metalurgy& DON'T leak &won't "mark/score" the shaft,
Modern neoprene seals if there's even a slight "nick" in the sealing lip will go hard(run dry) resulting in "marking/scoring" on the shaft causing a groove negating use of a aluminium speedie sleeve&in worst case scenario expoy to fill in the groove(s).
Oldcarbearings is offline   Reply With Quote
Old 07-16-2021, 09:06 AM   #3
duke36
Do you have a part number for the leather/felt type?
duke36 is offline   Reply With Quote
