Old 05-30-2021, 01:16 PM   #21
Pamlico
Pamlico's Avatar
Default Re: 272 Y-block oil leak- need help quick- show time
I half-heartedly remember hearing of a shade-tree fix for those filter plates that are warped. Something about seating it in a tube of the right diameter (maybe an old starter housing) and giving it a rap with a large hammer. The goal was to restore the "bell" shape and cure the flatness of it. I can't remember the source. (CRS)
Pamlico is offline   Reply With Quote
Old 05-30-2021, 03:54 PM   #22
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 272 Y-block oil leak- need help quick- show time
Dear Fellow CRS Participant ...
Here Is The Link - http://www.y-blocksforever.com/tech/...il_filter.html
You need this if your engine produces high oil pressure (IMO of course) -
ALUMINUM PLATE - http://www.2040-parts.com/spin-on-oi...-352-i1607964/
BLAST FROM THE PAST - https://www.fordbarn.com/forum/showthread.php?t=229224
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 05-30-2021, 08:01 PM   #23
Pamlico
Pamlico's Avatar
KULTULZ you nailed it!
Old 05-30-2021, 08:47 PM   #24
down-the-road
down-the-road's Avatar
Good picture at that link to show the components.
What language is being used on the map to show the location of the supplier?
There are comments on a few different forums questioning the legitimacy of the 2040 Parts site. Check out these comments here on the HAMB: https://www.jalopyjournal.com/forum/...bsite.1038855/
Might be a good idea to look into other suppliers before sending credit card information.
down-the-road is offline   Reply With Quote
Old 05-31-2021, 04:35 AM   #25
KULTULZ
KULTULZ's Avatar
Question Re: 272 Y-block oil leak- need help quick- show time
... hmmpf...
THANX! for the warning!
I would think John Mummert would carry this.
Didn't see the ruskie ...
Old 05-31-2021, 06:59 AM   #26
Dobie Gillis
Dobie Gillis's Avatar
The site says the seller's location is Middleburg, PA. Didn't see any foreign languages.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 05-31-2021, 11:36 AM   #27
dmsfrr
dmsfrr's Avatar
2040-parts is apparently a scam website created to separate you from your personal or credit card information. Their parts ads are noted as copied from other websites.
See the comments and reviews....
https://www.webwiki.com/2040parts.com
https://www.dootalk.com/forums/topic...alert-2040com/
https://www.forbbodiesonly.com/moparforum/threads/is-2040-parts-com-a-valid-parts-site.160360/
dmsfrr is offline   Reply With Quote
Old 07-04-2021, 03:15 PM   #28
Tom in TN
Tom in TN's Avatar
Originally Posted by Daves55Sedan View Post
I wouldn't do that. The older, quality adaptor plates are stamped of 12 gage? metal, so you wouldn't be able to take off too much before drastically weakening the filter gasket surface.
Years ago, I had an original adaptor plate on my spare Y-block that actually had a noticable dent in the gasket surface. I found a large piece of heavywall pipe that had been cut off square, set the adaptor plate upside down on a clean flat surface. I set the pipe on it and a wooden block on top of the pipe and blasted it with a sledge hammer. It popped the dent right out. I used that y-block with that adaptor plate for many years without any leaks.
I'd hate to think what a machine lathe would do to one of the cheap Chi-Com repro plates made of paper thin metal. Heck, they might be easy enough to cave in by tightening the spin-on filter too tight.
Question, was the original FOMOCO adapter arrangement a "2-plate" solution?
Does this sound correct for a Ford set-up? "Ford Y-block 239 256 272 292 312 OEM Oil Filter Plate & Adapter Spin ON Adapter Comes with all the hardware gaskets in photo need replacement. This is the OEM canister plate and adapter ,and than the spin on plate and adapter that screw into that"
Pic shows 2 plates...was it?
Tom in TN is offline   Reply With Quote
Old 07-04-2021, 04:20 PM   #29
KULTULZ
KULTULZ's Avatar
Does this sound correct for a Ford set-up? "Ford Y-block 239 256 272 292 312 OEM 1) Oil Filter Plate & 2) Adapter - Spin ON Adapter Comes with all the hardware gaskets in photo need replacement. This is the OEM canister plate and adapter ,and than the spin on plate and adapter that screw into that"
What picture are you referring to?
Old 07-06-2021, 06:35 AM   #30
Tom in TN
Tom in TN's Avatar
Kultulz- The picture on the site where I found this for sale... one plate has 2 slots at the top, the second plate has 3 holes in it and there are gaskets between both of them...
I don't have a way to grab/post the pics, but is that really necessary? The basic question is, does the FOMOCO adapter system use 2 plates that are installed on top of each other?
Hoping those that are familiar with the factory piece(s) can let me know...
Old 07-06-2021, 08:34 AM   #31
KULTULZ
KULTULZ's Avatar
Post Re: 272 Y-block oil leak- need help quick- show time
Kultulz-
YOH!?
There is only one plate used on either system. The original cartridge type filter plate is removed and replaced with the plate and adapter from the spin-on FORD KIT (B7A 6882-A).
If the KIT is not in a FORD box or MOTORCRAFT bag, it is most likely junk.
I was just wondering about your source as to quality.
Old 07-06-2021, 03:27 PM   #32
Tom in TN
Tom in TN's Avatar
Thank you sir... so the seller has no idea how it's supposed to be installed... I knew I could find the straight scoop in here- thank you!!
ps not sure what YOH means, so I can't respond to it...have a good 'un...
