Old 05-07-2021, 04:17 PM   #1
nkaminar
nkaminar's Avatar
Default Re: Hydraulic brake balancing
I stand corrected. My brakes must have been a different year as they had the little star wheel at the bottom. Or, that was maybe 55 years ago, so the brain cells that held that information may be gone.
Pdgx, please post your fix when done so that we may all learn.
nkaminar is online now   Reply With Quote
Old 05-07-2021, 07:57 PM   #2
Jim Cates
The problem I had was: My master cylinder did not have a check valve.
Drum brakes should hold 10 pounds of pressure in the lines.
Jim Cates is offline   Reply With Quote
Old 05-08-2021, 06:12 AM   #3
Patrick L.
Patrick L.'s Avatar
Chris,
I posted a big response and then deleted it. I deleted it because you are right. The rear shoe is the primary/shorter of the two and the short end goes toward the bottom. I do know/remember these are anchored and not energizing.
But Boy, I sure don't remember that shoe orientation and I come from a Ford garage. I guess the Alzheimers thing is kicking in.
I do still see shoes that are installed incorrectly on other vehicles, in that, many times the primaries are on one side the secondaries on the other or they are on backwards.
Old 05-08-2021, 10:48 AM   #4
Jerry in Shasta
Jerry in Shasta's Avatar
Are the left and right cylinders exactly the same.
my WAG at the problem
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 05-09-2021, 01:06 PM   #5
denis4x4
denis4x4's Avatar
I got some after market shoes that were incorrect and sent the original shoes to an outfit in Phoenix bond new linings on them. NAPA and Speedway wheel cylinders are made in Mexico
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
