Old 11-14-2024, 12:54 AM   #21
Tomc1
Default Re: Is it possible to install a fuel pump incorrectly on a 292 Y-block
How do
you adjust the hood to radiator on a 1933 ford coupe?
Tomc1 is offline   Reply With Quote
Old 11-14-2024, 09:02 AM   #22
KULTULZ
KULTULZ's Avatar
Arrow Re: Is it possible to install a fuel pump incorrectly on a 292 Y-block
Originally Posted by Tomc1 View Post
How do you adjust the hood to radiator on a 1933 ford coupe?
You need to post here - https://www.fordbarn.com/forum/forumdisplay.php?f=4
1st post - no harm - no foul ...
KULTULZ is offline   Reply With Quote
Old 11-14-2024, 10:50 AM   #23
zuburg
zuburg's Avatar
Turned out to be the condenser in the distributor. Yeah.
zuburg is offline   Reply With Quote
Old 11-14-2024, 02:38 PM   #24
zuburg
zuburg's Avatar
Turned out it was just the condenser in the distributor. Yeah !
Old 11-21-2024, 01:16 PM   #25
Gene F
Gene F's Avatar
Did you try starting it in neutral? Converting from manual to automatic....wonder if there was a safety switch on the clutch pedal.....
Gene F is offline   Reply With Quote
Old 11-21-2024, 09:49 PM   #26
zuburg
zuburg's Avatar
My car has an automatic and I replaced the neutral safety switch for the one that requires it to be in Park to start.
