Old 03-29-2021, 03:12 PM   #21
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Front End Rebuild Questions
Originally Posted by Cape Codder View Post
[B]Tacoma Bob[/B So did you observe any wear with the perch or axle or nut? With the cotter pin installed I cannot see how the nut could come loose.
I'm not saying the nut was not loose, but cannot understand why/how if none of the above is not worn.
Great question! I did a major project back in 2004. Complete engine, trans and rear end rebuild. I had the front end out and took the cotters out of the perches. My intent was to clean and paint everything. I took the nuts off and replaced after painting. Unfortunately I did not tighten enough and put new cotters back in. Eventually the car began to wander. It took me a number of years and replacing everything imaginable to finally solve the problem. I was frustrated and thought what the hell. Took the cotters out and using a socket and breaker bar cinched the nuts REAL tight. New cotters and the problem was gone.
Tacoma Bob is offline   Reply With Quote
