Old 10-01-2020, 10:55 AM   #1
GB SISSON
GB SISSON's Avatar
Default '40 front fenders
I discovered a friend has a set of 40 fronts for a 'farm truck' project. I am thinking this is a better use of the 4wd chassis I have than the 'sportsman' project. Upon more inspection the frame just isn't up to that standard. It's an off brand chassis with the same track width as the 40 but not the 42-47 so I am chasing down some sheet metal. I have a '47 cab and a '47 factory truck cowl. I also have a 41 pickup hood. Looks like the hood is a good fit to my cowls and I can fabricate brackets for the '40 fenders. The fenders were described as kinda rough which could be ok with me. I will see them today. Will they work out all right with my later cowl? I don't know if they have the headlight assembly. Hope so. Then I need a serviceable grille. I would most likely build a small flatbed, perhaps a pto winch with a small wrecker boom that was made from model A frame rails. I have both. A guy has to have a project.
