#1 |
dave if you would like some photos send me an email to [email protected]. go huskers my wife is an alum
#2 |
What does this mean, please?
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
#3 |
Cornhuskers is the name of the sports teams for theUniversity of Nebraska. Husking is the removal of the outer 'leaves' husk on an ear of corn.
#4 |
I agree the piston will probably function as a piston. However, I would be concerned about the weight of the piston. Generally pistons are weighed in grams, and come as a matched set; that is they all weigh very close to the same weight. Sometimes you have to take a little metal off to achieve the same weight for all four pistons. I do not see how you could have a balanced set of pistons (all weighing the same) with that chunk missing. Using that piston may cause a vibration you will not like..
#5 |
I agree , I wouldn't use that piston unless I had to .
