Old 09-09-2020, 10:45 AM   #21
fixitphil
Default Re: using a 12 volt system with the 6 volt horn
You did say insulated didn't you??
FixitPhil
fixitphil is offline   Reply With Quote
Old 09-09-2020, 12:57 PM   #22
Tom Endy
Tom Endy's Avatar
The wire has to be insulated. Wire used for winding transformers is solid and has an insulation coating applied. If you have an electronics supply in your area they will have it. otherwise you should be able to find it on line.
Tom Endy
Tom Endy is online now   Reply With Quote
