Old 07-17-2020, 02:25 PM   #1
SDJason
SDJason's Avatar
Default Re: Frustration
Maybe a long shot, but I had similar symptoms just over seven years ago...it turned out that the screw on the points block was loose - after tightening that down, everything worked fine.
SDJason is offline   Reply With Quote
Old 07-17-2020, 03:41 PM   #2
Woodie1
Woodie1's Avatar
That screw is nice & snug SDJason. Thanks.
Woodie1 is offline   Reply With Quote
Old 07-17-2020, 03:59 PM   #3
Tinbasher
Tinbasher's Avatar
Check to see if the Distributor is grounding to the engine. Put a jumper between the dist. body anda ground. Sometimes rust will form between the too and you get a poor ground. My thoughts.
Tinbasher is offline   Reply With Quote
Old 07-17-2020, 07:42 PM   #4
shew01
shew01's Avatar
Does the coil get warm to the touch after the car is otherwise cold? Mine did that, and it turned out to be a defective pop out switch.
shew01 is offline   Reply With Quote
Old 07-17-2020, 08:30 PM   #5
Woodie1
Woodie1's Avatar
I don't have a pop out switch anymore. This one is made by Nu-Rex. I'll try these ideas when I get at it again.
Old 07-18-2020, 11:30 AM   #6
katy
katy's Avatar
When I first restored the car it would fire right up, that was 36 years ago. I must be over looking something now. Any ideas?
I went out this morning to test things on the car & the battery was dead.
Try a new or different (good) battery
