Old 04-25-2020, 01:55 PM   #1
GB SISSON
GB SISSON's Avatar
Default Dropped spindles for clearance?
Having installed this diesel engine in my 47 ford tonner (otherwise stock), I find I would like more clearance between the drag link and the oil pan. In 30 trial miles it has not made any contact with the freshly painted pan, but I could see scenarios where it would. I picture a sort of 'U' bend in the drag link but went online about a dropped drag link. Turns out they make drop arms for ford spindles. My tonner uses same as half ton spindles. Couldn't tell from the pics how they bolt to the spindles. Do the two top backing plates bolt into the slingshot ends and I cut off the existing arms? The current stock drag link has about a 20 degree kink downwards on the pass side already. I would probably use the 1 3/4" drops from speedway? Make a new drag link?... But bending tubing? Looks like the stock link is solid rod. Any ideas? I could get a pic soon. Thanks
