Old 11-30-2019, 10:22 AM   #21
AllenV
AllenV's Avatar
Default Re: '55 F100 new project, new member
Well, I am destined to find out, and add my own Pertronix anecdote in time.
On another topic: As I was changing spark plugs yesterday I found that cylinders 1,2, and 7 have had threaded inserts installed. See photos. remarkable in that the plugs with inserts sit substantially further out than the unmolested plugs. How common is this? Should I be concerned? shopping for heads?
The motor seemed to run well when I bought it. Though the choke was stuck full on during the test drive. That was due to a broken choke cable housing, since replaced. As such I have so far only experienced a very fast idle with full choke and a broken vacuum diaphragm on the distributor . I am expecting a much more civilized experience when I get the new distributor installed and timed. Thus I ask the collected expertise if having 3-of-8 plugs "helicoiled" might be a cause of rough or uneven idling.
Allen
'55 F100 with slightly newer 292 Y-block
find the detailed project story at
https://www.ford-trucks.com/forums/1...o-project.html
AllenV is offline   Reply With Quote
Old 11-30-2019, 11:47 AM   #22
dmsfrr
dmsfrr's Avatar
Those look like anti-fouling inserts, to help keep oil off the sparkplug tips.
dmsfrr is offline   Reply With Quote
Old 11-30-2019, 12:45 PM   #23
AllenV
AllenV's Avatar
That is a new one for me. Didn't know of such things. I'll leave 'em for now. See how it runs and get through the compression and leak-down tests.
Thanks again
Allen
Old 12-01-2019, 04:44 AM   #24
KULTULZ
KULTULZ's Avatar
Post Re: '55 F100 new project, new member
Used to control poor cylinder oil control - fouled spark plug.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 05-29-2020, 12:27 PM   #25
AllenV
AllenV's Avatar
Smile Re: '55 F100 new project, new member
I am finally back at work on Nellie ( the F100)
Finished with the front spring replacement so she is now safe to roll on her own.
The new FBO distributor with the Pertonix III ignition is installed along with the flamethrower III coil and a new set of plug wires. Recall, that to get the manifold vacuum wanted by the new distributor I tapped into the manifold port used by the PCV, just forward of the carburetor. Then I plugged the ported vacuum on the carburetor.
After some fiddling of chokes and verifying of fueI, air, and spark she lit up! Very first operation since I flat-bedded her home. The uploaded picture is taken with the vacuum disconnect and vacuum line run to a vacuum gauge. The low RPM timing has only just been set at 14 degrees BTDC. It has only been running a few minutes. It is ticking along at some low idle RPM, as yet not measured. The chock is off. That vacuum needle is bouncing only less than 1 needle width.
Sounds decent, oil pressure shows okay pressure, vacuum look okay.
I found a fuel leak at the pressure gauge in front of the carb. I’ll fix that and hook up the vacuum advance….
Allen
Old 05-29-2020, 01:10 PM   #26
dmsfrr
dmsfrr's Avatar
Originally Posted by AllenV View Post
... new FBO distributor ... Recall, that to get the manifold vacuum wanted by the new distributor I tapped into the manifold port used by the PCV, just forward of the carburetor. Then I plugged the ported vacuum on the carburetor.
Unless the instructions for the aftermarket distributor specifically say "manifold vacuum", the vacuum line for the distributor is more correctly connected to the vacuum fitting on the carburetor.
Old 05-29-2020, 02:14 PM   #27
AllenV
AllenV's Avatar
Not to worry, the FBO distributor definitely wants manifold vacuum. I verified this with them twice on the phone.
More data:
Idle is 950 rpm
oil pressure varies from 18psi at idle to 38 psi at higher rpm. This is at 190 F temperature. Indications are from an after market
BUT! The brake pedal goes right to the floor! I don't recall this "feature" during the test drive.
Allen
Old 05-29-2020, 03:39 PM   #28
dmsfrr
dmsfrr's Avatar
That's the 'Meet the neighbors' option. So you have to converse with the folks across the street about damage to their car when attempting to pull out of your driveway. My red '55 almost had that option when the brake booster failed.
The brake fluid may have leaked out somewhere or the seals in the master cyl are gone.
Old 05-29-2020, 05:01 PM   #29
AllenV
AllenV's Avatar
Fortunately we only have llamas across the street
I was always imaging a complete brake rebuild would be needed. Just not right away. Debating with myself the relative merits of piece-mealing it versus just buying all new parts and doing everything now.
Allen
Old 05-29-2020, 05:31 PM   #30
rotorwrench
rotorwrench's Avatar
Piece mealing generally works when thing are already functional but worn. You will have to see if your master & wheel cylinders are rusty or not.
Old 05-30-2020, 06:19 PM   #31
AllenV
AllenV's Avatar
Results of Brake Inspection
Executive Summary: Lots of gunk. Lots of cracked and broken rubber. Creative use of heavy wire on the clutch mechanism. Novel threaded-rod clutch push rod.
Front brake shoe width: 1.75 inch
Rear brake shoe width: 2.00 inch
Evidence of too-wide shoes running in narrow rear drum
Front shoes were put on rear and vice-versa
No obvious fresh brake fluid oozing
Discussion: There is plenty of rust and gunk and most of the rubber is beyond its useful life. The shoes and drums will need to be replaced as the wide shoes in narrow drums have gouged the inner edge of the drum and the narrow shoes in the wide drums have created a wear “step” that would truly mess up operation if an attempt was made to install new wide shoes. The mechanic (me) recommends all new hydraulic cylinders, master and slave as well as new springs and clips. Will need to diagnose the function of the after-market heavy wire.
Photos attached
Bonus photo of the completed front spring install
Allen
Old 05-31-2020, 12:11 PM   #32
AllenV
AllenV's Avatar
Poking at some more. I now see fresh seepage out of the master cylinder .
Allen
Old 06-11-2020, 04:54 PM   #33
AllenV
AllenV's Avatar
Default Frame Crack
Well… As I was pulling the master brake cylinder I happened to spot a crack in the right side frame rail. See attached image. This is fully half-way through the frame. Location is just at the front edge of the battery box. It must be fixed, and soon. Now the brakes are on hold while I pull the cab off. My plan is to drill a hole at the lower terminus of the crack and then weld the entire length. Then add 1/8-inch doubling plates on the top and side.
Stay tuned.
Allen
Old 06-12-2020, 12:46 AM   #34
Daves55Sedan
Daves55Sedan's Avatar
You might be able to have the drums with the grooves turned down and re-use them, but the other two may need to be scrapped. I noticed a lug bolt missing or twisted off of rear wheel hub.
Its a good idea to drill a hole to terminate that frame crack before welding. I noticed at the top where that crack starts, the lip appears to have been bent down. Maybe heat and straighten using 1/4 inch thick plates above and below tightened down with heavy duty C-clamps, but you would need to work real fast while the metal was hot.
1958 was the first year Fomoco had "FORD" letters embossed onto the valve covers. Earlier years had plain valve covers with a decal.
Those fittings in the heads look like spark-plug anti-foulers. They are there to protect the plugs from getting fouled with oil. May be necessary to replace rings, reem the cylinder wall ridges and do a valve job. After that, those old top oilers will no longer ever be necessary as todays oil is much better refined than it was in the '50's. You have a standard single-action fuel pump with a fuel pressure guage going to a '57 or later 2-bbl carb. There should be no need for a pressure guage with this application and no need for a regulator either, as this type of carb doesn't ordinarily have float inundation problems. But what are you doing about windshield wipers? Electric? If they are vacuum operated, most people would recommend swapping the single-action pump for the dual-action type with vacuum booster for the windshield wipers. I think wiper motor is mounted on firewall under the dashboard.
If you have converted to 12-volt electrical system, the '58 engine is already set up to use the small, stubby temperature sending unit which will not work right with the '55 guage. Maybe see if you can find a '58/59 guage that will fit the '55 cluster? Fuel guage and sending unit; maybe put in a resistor ahead of the guage power circuit?
Daves55Sedan is offline   Reply With Quote
Old 06-12-2020, 08:11 AM   #35
AllenV
AllenV's Avatar
Dave55Sedan, you raise a lot of important issues. These are the things that are contributing to the to-do list. Let me try to work my way thru your list.
Brake drums: I bought 4 new from mid-fifty, along with new slave and master cylinders.
Frame crack: I am wondering why the frame is bent that way. There is no current evidence of something contacting that area. I’ll have to decide what to do about straightening after I have it exposed, the battery box off, those rivets removed. At the moment I am reluctant to put enough heat in there to pound it straight for fear of warping that frame section. But, heating before I weld the crack may be forgiving of distortion. It LOOKS like that bend is benign in that there is plenty of gap between the frame and cab.
The motor: yes, those are plug anti-foulers. If the motor needs a rebuild, I’ll do it. The oil pressure looks okay. I’ll have to monitor oil consumption for a bit. That said, it runs strong and I am sure it needs a valve adjustment. It drips copious amounts of oil and is covered in muck below. I think the rear main seal is shot and maybe the pan gasket. When the cab is off I plan to clean it thoroughly. I’ll pull the transmission and inspect/replace the rear seal. What is the general experience with these seals? Can it be removed/replaced with the crankshaft in-situ? Ideally, I would delay the motor rebuild while I complete another car project that has been pushed aside by this one. So popping in a new main seal, pan gasket, clutch and engine mounts while the cab is off is my preferred scheme at the moment. The fuel pump is an old aftermarket electric unit. I put the fuel pressure gauge on as I don’t trust the pump and I wanted to be sure it is a 4-5 psi unit. What do you mean by “ no need for a regulator either”? What have you spotted that I didn’t recognize?
Windshield wipers: I have no idea. I think they are electric. I don’t know if they work. I’ll have to investigate and get back to you. Sounds like your preference is for electric.
12V conversion: YES it is 12V. It has a Delco-style single-wire alternator and internal regulator. I’ll go hunting for the temperature sender. It has occurred to me that he MOTOR has always been 12V so the sensor would be a bit newer.
’55 cluster: as you can see, I have plenty to do. Putting the cluster back in working order can wait.
Allen
Old 07-03-2020, 06:56 PM   #36
AllenV
AllenV's Avatar
Default The Frame is Revealed
Got the body work off of the frame.
Allen
Old 07-04-2020, 02:11 PM   #37
50fordcoupeman
50fordcoupeman's Avatar
Originally Posted by joe plumber View Post
There is nothing wrong with Petronix as long as you use the correct coil with it.Ive had one for 15 years with no problems
I also am using the Petronix in two engine applications. Have had them both for 5 plus years with no problems. Knock on wood!!
50fordcoupeman is offline   Reply With Quote
Old 08-10-2020, 09:41 AM   #38
AllenV
AllenV's Avatar
Default Motor is out
I need to catch you guys up on a bunch of activity.
In preparation for the frame repair, the motor is out. here are some photos
Allen
Old 08-10-2020, 09:46 AM   #39
AllenV
AllenV's Avatar
Default details of the crack
Here are some shots of the main frame crack. I also found that the cross rail at the rear of the cab had a cracked section.
Allen
Old 08-10-2020, 09:55 AM   #40
AllenV
AllenV's Avatar
Default Straighten that which is bent
I needed to determine which part of the frame was bent to generate the offset seen in the previous post. Using a sight string and carefully measuring the distance from the string to the OUTSIDE rail edge I found that the bending was on the short section forward of the crack and aft of the transmission cross rail.
I drilled a hole at the tip of the crack to prevent it growing as I began to manipulate it.
Judicious heating and beating brought the rail back into position.
Allen
