Old 07-04-2019, 11:25 AM   #1
dennis lumbert
dennis lumbert's Avatar
Default Re: Is this bearing reusable
I had to disassemble my rear axle due to axle housing repair sleeves wearing out in just 1500 miles.I discided to check the drive shaft needle bearing which I had replaced with a new repro part at the time of the axle overhaul.Im very glad I checked it because the rollers were getting close to coming out of the cages due to improper heat treating of the cages.Fortunately I had saved the old original bearing which was in good condition so I put that back in service.This bearing had been purchased about 10 years ago from one of the model A vendors. I wouldn’t use a pitted bearing like the one you have but just because a bearing is new doesn’t nessasarilly mean it will give good service. Dennis
File Type: jpg 6ACBFF0F-1D1B-464A-AE80-B2479A8A07F0.jpg (38.7 KB, 17 views)
File Type: jpg 2FB5B877-52A3-4C01-A068-23C5295EEFC9.jpg (49.0 KB, 14 views)
dennis lumbert is offline   Reply With Quote
