#21 |
#22 |
IMHO, you would be better off using a wedge splitter in the center port. I have had good luck with the. Will not help the looks but would serve a purpose.
#23 |
I guess splitting isn't all that it is cracked up to be. I guess I'll stick with one hole.
#24 |
Good decision!
#25 |
One other thing you might want to consider is the effect that four pipes might have on the flathead sound. In the firing order, cylinders 2 & 1 fire one right after the other while all other cylinders have a non-adjacent cylinder firing so there could be a slightly different sound pattern coming out the pipes. You could lose the unique flathead sound.
#26 |
#27 |
#28 |
Interesting. I would have thought that shoving a chunk of cast iron into an already restricted exhaust passage would restrict it even more.
#29 |
The wedge splits exhaust from the two center cylinders and directs it out the port. Some say it is not help. I have had good experience with a cooler running engine.
#30 |
tried it sounded awful [chev] didnt last long pulled it out now it sounds like a flathead should
#31 |
I was skipping thru just looking at the pics till I got to that one.....then I went back to find out what the heck was going on!!!!........Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#32 |
