#21 |
20180519_151648.jpg This is my Weber setup.
#22 | |
![]() Quote:
Corley ----------------- Subscribed to the KISS principle! |
#23 |
The engine has a Eubank cast nodular (ductile) iron model B balanced crank, in a Model A block. Model B cam, inserted bearings, pressurized oil on all bearings, Stipe/Specialty Cam Hi volume oil pump for A/B engine, 25 lb. aluminum flywheel, 1939 Ford transmission with a Borg Warner overdrive. The intake is what I don’t know the manufacture of.
#24 |
Ronnie,
Looks like a fuel pressure gauge on the fuel line. Are you using the standard fuel tank or some other setup? My wife is afraid of the standard tank up front so I was thinking of using a 32 tank in back with a fuel pump. David Serrano |
#25 |
I’m going to jump in here.....using a fuel pressure gauge on both engines. The ‘29 in the avatar has the stock tank and the roadster has a rear tank. The ‘32 tank is the prototype of the Pinto and we know how that turned out!
No restorable Model A's were harmed in the building of this truck! |
#26 |
