09-09-2018, 11:59 AM | #21 |
Re: Play in water pump shaft
The title of this thread made me think of something else.
09-09-2018, 08:03 PM | #22 | |
You only need one. put it on the end of the shaft that is nearest the fan. The fan will keep the shaft from moving toward the block and the collar will keep it from moving toward the radiator. |
09-10-2018, 06:09 AM | #23 |
I contacted the previous owner of the A and he says and I quote " it is on with simulated studs, so you can take it off without taking the radiator off." I wasn't planning on taking the rad off anyway as a two blade fan doesn't require that, but what in the H are "simulated studs"?
09-10-2018, 06:20 AM | #24 |
I would like to see some kind of C shaped spacer of different thickness, as needed, that be can be slipped over the worn stop on the head. Would something like this restore the head stop to the correct depth?
John |
09-10-2018, 06:56 AM | #25 |
09-10-2018, 07:21 AM | #26 | |
09-10-2018, 07:22 AM | #27 |
You can buy the longer shaft, but I'd use the collar stop. Too bad Ford didn't have that.
09-10-2018, 07:41 AM | #28 |
OK.....the previous owner says.........
" The pump was originally held on by studs sticking out of the head and nuts on the front of the pump. You can't get the pump off without taking the radiator off because the studs are too long. The ones on that car are bolts that go on from the front of the pump. If you look at them the head is made to look like a stud and nut. Once you get them out there are no studs sticking out and there should be enough room to get the pump off." Ingenious! |
09-10-2018, 07:42 AM | #29 |
09-10-2018, 08:33 AM | #30 | |
Will I need to still tip the radiator forward at the top after removing the hood or will the pump and the impeller lift out without doing all that? |
09-10-2018, 08:37 AM | #31 | |
09-10-2018, 08:39 AM | #32 | |
09-10-2018, 07:46 PM | #33 |
Probably not if you have 1 inch clearance from the pump shaft to the radiator, like my original parts have.
09-12-2018, 06:04 AM | #34 |
Update: the pump came off without tilting the rad. Those simulated bolts that look like studs are an ingenious invention. Waiting on the new pump. Looks like a 20 min. job altogether thanks to those bolts. Getting a new fan as the old one had some stress cracks. Will run distilled water and Water Wetter in the rad until the cold comes which will be soon here in upstate NY. Then I'll fill her up with 50/50 green antifreeze, burn the gas up in the lines and carb, put her to bed and wait until Spring........
Don |
09-12-2018, 07:25 AM | #35 |
Napa Macs 1300 Rust Inhibitor is also usually recommended when using distilled water.
09-12-2018, 07:31 AM | #36 |
Also, my method is to fill her up with ethanol free, add some gas stabilizer like Stabil 360, run it, and to bed she goes. Should help keep condensation/water out, do not have to be concerned about E10 gas phase separation, and stabilize the gas.
09-12-2018, 07:45 AM | #37 |
Yes..almost forgot.......plus keep a full tank of gas. Less condensation at the top of the tank.
09-12-2018, 08:04 AM | #38 |
Is this needed on a new water pump? I thought the grease covered the pump lube part? I suppose the anti-rust additive is good for the rad and water jacket.....but I'm adding Water Wetter and they say that has anti-rust stuff in it. I'm using straight distilled water.
Bar-s-Leaks-Water-Pump-Lube-with-Anti-Rust |
09-12-2018, 08:31 AM | #39 |
Antifreeze is a good lubricant for the seal. Rusty water will eat up the seal, then the bearings.
And, that unexpected early freeze will bust the block on anyone not using antifreeze. Just ask Bert's about how many engines he sells for that reason. |
09-12-2018, 08:48 AM | #40 |
Water wetter has some pump lube, but I have had multiple Senior Members of the Barn recommend to also the MACs, so I do, do not remember if there was an explanation why to use both.
Depending on the type of leakless water pump your are using, modern bearings/seals remove the need for greasing. Advantage of this is a better seal (no drippage and mess in the motor bay) and no worries about over greasing and getting grease into the coolant clogging up your radiator. The grease/lead packing/packing nut is the seal on original water pumps, they are prone to drippage. The packing nut is to provide adjustment of grease/lead packing seal. Do not know if its is true, was told that the pump was actually designed to drip at a very low drip rate to help cooling the seal area and the pump shaft. Part of updates to original pumps and leakless pumps is to add a modern seal in the packing nut area. The water pump lube helps keep the seal conditioned. Not sure if there are other benefits to the lube. |
