Old 02-03-2025, 10:39 PM   #21
alexiskai
alexiskai's Avatar
Default Re: Gaskets 101, advice?
Originally Posted by PaintShaker View Post
Could someone tell me what exhaust manifold gland rings are? I'm guessing they might bridge the gap between manifold and block. My engine doesn't have any such thing.
See Bob's post earlier in this thread:
Originally Posted by Bob Bidonde View Post
the gland rings protect the gasket from burning. Be sure each gland ring, when installed, has a gap at its ends of 0.06" minimum to allow for expansion.
The word "gland" used in engineering means a sleeve or box that forms a seal to keep some kind of fluid or gas from leaking in or out. In this case, gland rings fit into a counterbore machined into the joint between the block and the manifold. They reinforce the manifold gasket so that exhaust gases have a harder time penetrating it.
Old 02-03-2025, 10:57 PM   #22
JayJay
The exhaust ports in the block have counterbores several thousands deep on the manifold side. There is a corresponding counterbore machined into each arm of the exhaust manifolds. For most of production Ford supplied steel rings that fit into the two these counterbores and bridged the gap. These glands serve two purposes: they align the manifold openings exactly to the block openings, and they center the gaskets to these openings. They also shield the gasket from direct contact with exhaust gases.
Over time, especially if the glands are not used, the rear of the exhaust manifold (especially #3 and #4) sags. If that is the case, you cannot use the glands since the four holes in the manifold no longer are in a line. Eventually you will get to the point that the sag is so severe that you cannot seal #4, and it will leak. I have removed a manifold that had a 1/2” sag at #4 compared with the line of #1 and #2. When you get to that point your only option is a replacement manifold.
There are quite a few folks who feel that the glands are not necessary, that they just complicate things. You can search and find plenty of discussions on this in the Barn. If your manifold is good or new, gland rings may help slow down the sag. A caveat is that when you deck the manifold sealing surface of the block, or deck the two manifolds together, you need to check the depths of the counterbores and make sure you won’t bottom out on the gland rings when you tighten. I do this by dry fitting the manifold with the gland rings but without gasket, if it sits flat then I’m good to go.
BTW, in terms of manifold gaskets, I’ve had the best luck with the two-piece copper sandwich gaskets used in late ‘31.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 02-04-2025, 10:52 AM   #23
katy
katy's Avatar
https://www.snydersantiqueauto.com/p...1312&cat=41892
Old 02-04-2025, 07:19 PM   #24
Vic in E-TN
Why 6 manifold rings on the Snyder page? They are for Model T 4 cylinder engines.
Vic
Vic in E-TN is offline   Reply With Quote
Old 02-05-2025, 11:12 AM   #25
katy
katy's Avatar
My bad, try: https://www.snydersantiqueauto.com/p...9405&cat=41733
