#21 | |
![]() Quote:
Ditto on Ken's comment... I have driven my '36 with it's Columbia for over 94.k. The only time I ever had a problem with the unit is when a thrust washer between an axle and other components seized causing the right wheel to lock up. That was a real thrill at 60+ mph..
Bill.... 36 5 win cpe |
#22 |
I too have driven many thousands of miles with Columbias. Only issue I ever experienced was in my 40 convertible one day and it felt like the rear of the car jumped off the ground. Got it back home and found that the pilot bearing on the rear of the pinion had came apart sending shrapnel through the rear end.
#23 | |
![]() Quote:
Phil Swanson |
#24 |
The '42-48 rear axle assembly is approximately 2" wider than the '40 assembly. I have a '46-48 Columbia under my '36 coupe, I up graded the car from a '36 Columbia to the '46-48 unit.
There are people that will tell you that you need to shorten the axle housings and axles, this in non-sense.. The difference in the width is less than 1" on each side, not a problem. This is all you have to do: disassemble the '40 differential, discard the axle housings, axles and rear spring. Install the '46-48 Columbia onto the '40 banjo, torque tube and radius bars, install the unit under the car, install the '46-48 rear spring, hook up brake lines and shocks. Use steel lines extending from the engine compartment to the rear end. Install '46-48 vacuum electric shift controls, making sure that you have the clutch safety switch assembly.. The whole installation is similar to the stock '40 setup, except you now have an electrically controlled OD, in lieu of a mechanically shifted unit. Additionally, the '46-48 Columbia's are much better than the earlier ones..
Bill.... 36 5 win cpe Last edited by blucar; 08-24-2018 at 12:08 PM. |
#25 |
Best advice you can have is to order the original Columbia literature from one of the peddlers. There are parts lists, installation instructions and driving instructions available which will take the guess work out of it for you.
#26 |
can this unit be used with a Chevrolet rear or Ford exclusively? Q2: only a banjo differential? thanks |
#27 |
Only Ford and Auburn.
#28 |
NEVER depress the clutch when shifting to OD????
Tim Carlig |
#29 |
The Columbia will not shift unless the clutch is fully depressed. There is a vacuum control on the clutch pedal. Unless the clutch is depressed vacuum will not reach the shift cylinder.
#30 |
I have a 37-41 Columbia in my '32 and love it. The vacuum shifting unit is a great mechanical device and I have no desire to change it to an electric solenoid.
I have a Columbia section in the Techno Source ... file below.
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source-for-the-1932-thru-1953-Flathead-Ford |
#31 | |
![]() Quote:
Tim Carlig |
#32 |
#33 |
Great, glad it helped you.
Glenn
#34 | |
![]() Quote:
Totally random trivia: apparently in 1937 the Columbia Axle Co tried out making overdrive axles for Chevrolet cars. This must not have met with much success since these are basically unknown today and apparently a handful exist: https://vccachat.org/ubbthreads.php/...938-chevy.html Last edited by 38 coupe; 04-20-2025 at 08:26 AM. |
#35 |
after studying cut away & section drawings, it's a wonder they worked at all.
transmissions have replaced welding & electricity as the "black arts" to me. |
