#21 |
So the engine guy didn't put the engine on a test stand and start it to help break it in and to see if everything is okay?
#22 |
This engine needs to be Plastigaged. You need to know that the clearances are adequate. My guess is that the mains are at zero clearance.
#23 |
I missed the post where you removed the plugs and starter as suggested and tried turning it. That might solve your problem.
Charlie Stephens |
#24 |
so when the guy put it together make's me wonder how hard the crank turned over so that he could install the rods,piston or if he was even able to check crank end play
it had to have been able to turn at that time someone else suggested the flywheel bolts as too long. pull it back out and start over checking the parts that you installed before taking any part of the motor apart if you take any part of what he did apart he has reason to tell you no warranty if he offered any in the first place Terry |
#25 |
This makes me absolutely ill & sick that there are still people that have no clue how to assemble an engine and take good money for it.
Railcarmover & Kohnke have it right. Follow their advice before you make it worse. Jim |
#26 |
#27 |
"don't want to shear a rear axle key"?????? If you're worried about shearing an axle key, you better get out to your garage/shop right now and tighten those rear axle nuts! They must be too loose! The matching tapers of the axle shaft and the hub are what handle the load, not the key. With the nut properly torqued, the key is just along for the ride.
#28 | |
![]() Quote:
#29 |
I was reading in old book--- if it takes one horse to pull it around in gear it's ok, if it takes 2 horses it's too tight
#30 |
#31 |
I hear/see a bunch of knowledgable people jumping to conclusions. First check to make sure nothing external is causing the engine to be locked, THEN if it is too tight to turn bring it back to the rebuilder and have them fix the problem. Getting in there now and messing around will only void any warranty you have. If this is a reputable rebuilder let them defend their reputation. The LAST thing you want to do is get into a dispute needlessly. Anyone can make a mistake, its how you re-address your mistakes that tests your true character.
#32 |
OMG OP disappeared. Must have been cranking to start in gear and drove through the garage wall.
#33 |
Just a thought, but I have a couple of times put the bolts in the starter incorrectly and ended up with the upper bolt up against the flywheel and nothing would move. Take the plugs out and take the starter off and if she won't turn over with the crank then do nothing until you can get knowledgeable help. Ernie in Arizona
#34 |
Sounds to me like that 'engine rebuilder' is yanking your crank. Sorry this happened to you. No doubt there are a lot of other things wrong too, and even if you get the thing going it will probably crap out within 800 miles of use.
This guy didn't know what he was doing from the sounds of it. |
#35 |
#36 |
You can't install the starter bolts incorrectly, because all 3 are 1" long.
You can install the incorrect bolt however. |
#37 |
Don't you just hate it when you never get to hear the "rest of the story"?
Corley ----------------- Subscribed to the KISS principle! |
#38 |
I assembled an A engine once using permatex assembly lube on the mains and rods the stuff was so sticky I could not turn the engine over with a 2' breaker bar. Babbitt was new and clearances were correct had two clean the lube out and assemble with light oil then engine turned normally
#39 |
I have a '31 engine rebuilt by a very reputable builder. When new it took much more than 75 foot-pounds to turn it. Most of the drag was in the "asbestos" seals at the ends.
You might put a large pipe wrench on the hand crank with a pipe slipped over the pipe wrench to get more leverage. My 6-volt start turned it over fast enough to start it when it was new. |
#40 | |
![]() Quote:
