07-21-2018, 11:37 AM | #21 |
Re: model B motor in model A chassis
07-22-2018, 09:55 AM | #22 |
Anyone sure on Oil pump?
07-22-2018, 10:21 AM | #23 |
J Franklin is correct, see November 1932 Service Bulletins.
Bob |
07-22-2018, 04:05 PM | #24 |
Thanks for information guys!
10-20-2018, 06:16 PM | #25 |
Will a model A distributor work okay in the model B engine?
10-20-2018, 06:36 PM | #26 |
10-21-2018, 08:25 AM | #27 |
My model a engine has model b crank and cam in it.
10-21-2018, 09:12 PM | #28 |
No.
10-21-2018, 11:12 PM | #29 |
Kong Jackson, Ed Winfield and myself in 1976. B engine, 39 transmission, model A rear end in a 29 roadster pickup. That is a Cook four port head with a one of a kind Kong ignition. the other side of the engine had two downdraft Winfield carbs.
Wish I still had it |
10-22-2018, 02:51 PM | #30 |
gmdy, I still have my Cook, last ran on the salt @ 167 MPH, on alky, with a turbo. Steve Serr of Miller hi-speed is in the process of producing a repro, improved Cook.
10-23-2018, 06:25 PM | #31 |
Thanks for the info. guys. Probably won't have a Cook four port head.
08-25-2020, 11:38 PM | #32 |
Wen I put a ModelB engine in my Model A, instead of cutting the model B oil pan, I enlarged the semicircular opening in the rear of a model A oil pan to fit into the cork seal channel in the Model B rear main cap. Worked fine.
Model B oil pumps shaft were cut down to a smaller diameter between the upper and lower pump bearings to improve oil flow in the pump body. Model A shafts were straight. |
08-26-2020, 03:08 PM | #34 |
In England all "B" engines were serialled on the block pad . The law required that the engine itself must be serialled . AA trucks in England were built into 1936 . I had a 1935 AA with AA 4981139 stamped on the block . These engines had a "B" oil pan with no shroud attached . This is just to clarify if someone has a "B" engine which has a serial on the block ,they are a more robust engine than the Detroit engine with a thicker top deck and are not prone to cracks anymore than a "A" engine .In WW2 they were used in welders ,generators etc etc and some ran on kerosine with cast iron pistons and special exhaust heated inlet manifold . More astounding useless information !!!
John in same place same weather . |
08-26-2020, 04:47 PM | #35 |
John,thanks for that interesting history. The Ford flatheads had the number on the transmission housing. Did they fit under the same rule? 32 on.
John
Welcome each day |
08-27-2020, 05:41 AM | #36 |
That is an interesting question .I do not know anybody with an English V8 but I will investigate and let you know.
08-27-2020, 04:51 PM | #37 |
Thanks
John
Welcome each day |
