06-13-2018, 07:17 PM | #21 |
Re: Just bought a '51Merc
WOW! That's a very Beautiful Car!
06-13-2018, 08:12 PM | #22 |
06-13-2018, 08:13 PM | #23 |
06-13-2018, 09:27 PM | #24 |
Given the rock salt used in Minnesota to melt the ice and snow on the streets during winter months, I suggest that Minnesota is a "rust belt" state as well - one of the worst in fact....
06-13-2018, 09:48 PM | #25 |
Sweet car!!
Ed "I find that the harder I work, the more luck I seem to have." - Thomas Jefferson |
06-13-2018, 10:32 PM | #26 |
06-13-2018, 10:51 PM | #27 | |
I live in city of Ramsey. Here's a few more pics. |
06-14-2018, 04:38 AM | #28 |
First time I recall seeing rubber sill plates on a Mercury.
Suspect that this was late production as some '51 and earlier years were Aluminum. This was probably due to Korean war restrictions that limited the use of Aluminum, Chromium as well as other materials.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 06-14-2018 at 06:53 AM. |
06-14-2018, 06:54 AM | #29 |
great looking merc. enjoy.
1949 F-1 Flatrod II (flat paint, flat motor) Keeping one more flathead alive It smoked, but gave it up 7/26/2013 East Glenville NY |
06-14-2018, 09:05 AM | #30 |
Wow Casey you did good, enjoy your ride.
06-14-2018, 09:36 AM | #31 |
A lot of stuff can get changed over the years. The sill plates can get damaged easily so I can see why they might have been changed. I don't think those are OEM but I could be wrong. The 6 passenger coupe aluminum sill plates are available but not for the 4-door sport sedan. I've found some good ones out there though. The Brown & Tan trim is pretty much same as one of my cars.
No overdrive with the Merc-O-Matic. It didn't need it with the tall rear axle gears they had. RPM at 70 mph should not be all that bad for an automatic car. You can get copies of the Owner's Manual for the 1951 cars. The Lincoln Mercury overhaul manual is a very good reference for repairs but you have to make sure the copy you get has all the 1951 updates. There was also good manual available for the Merc-O-Matic transmission as well but it is a separate item. Accessory manuals for them list available accessories from Lincoln Mercury. One of the Early Ford V8 Club members is in process of putting a book together for the 49 thru 51 Mercury cars. |
06-14-2018, 10:45 AM | #32 |
Do you know what the rear gear ratio is?
06-14-2018, 11:12 AM | #33 |
GORGEOUS! I love those early post-war Mercurys.
06-14-2018, 12:09 PM | #34 |
One beautiful car, best of luck with it.
06-14-2018, 12:18 PM | #35 |
Differential is 3:31 with automatic.
06-14-2018, 02:02 PM | #36 |
Ok thank you. I actually need to replace the rear end. It needs a rebuild. It has a loud clink. Sadly, I don't think I'm going to be able to find one in 8 days. I might not be able to bring the car to Back To The Fifties at the fairgrounds.
06-14-2018, 02:11 PM | #37 | |
The loud "clink" might be coming from the u-joint as opposed to the rear end - much easier to repair/replace the u-joint....
06-14-2018, 02:17 PM | #38 |
Love the lucky strikes on the dash, and the hat on the seat.. You are rocking it.
06-14-2018, 02:50 PM | #39 |
What a great car for your first classic. I’m certain you’ll get a lot of pleasure driving and showing it
06-14-2018, 03:04 PM | #40 |
