Old 06-13-2018, 02:45 PM   #21
josh1331
Default Re: R side directionals stay lit no blink..left ok
DMSFRR. Those other wires , turn, parking need to have wiring diagram or picture to see if mine are plugged in the right places. I will do cleaning for grounds, if I run as you suggested a separate ground wire where do I connect , right at that small junction box and do it for each wire? Car has been sitting for quite a while after engine was done so might be plugged in wrong ,john
josh1331 is offline   Reply With Quote
Old 06-13-2018, 03:17 PM   #22
dmsfrr
dmsfrr's Avatar
Originally Posted by josh1331 View Post
Model 63b
Fairlane 500 Club Victoria
Jumped the stop light two wires no stop lights came on but have power at two wires.??? Cleaned all connections. Now going to see if wires are connected right at junction box ear radiator where all light wires are.
It depends on which two stop light wires you put the jumper on, and where.
"power at two wires.???" Which ones?
There are 2 power wires for each of the; hi/low headlamps, front parking/turn signal, and the tail/brake light bulbs.
Each bulb has two different filaments, one for each function and a common connection within the bulb that must go to electrical ground, usually the body of the car. If any of the connections aren't good the bulb circuit won't work correctly.
dmsfrr is offline   Reply With Quote
Old 06-13-2018, 03:22 PM   #23
dmsfrr
dmsfrr's Avatar
You shouldn't need to run extra ground wires, except for testing purposes.
Here's a '57 wiring diagram. Not in color but the wires are labeled and you can zoom in on it.
http://www.oldcarmanualproject.com/t...re5765-195.jpg
Old 06-13-2018, 04:55 PM   #24
josh1331
PROBLEMS SOLVED. THANK YOU EVERYONE FOR INPUT". The stop light switch replaced gave me back stop lights. The Flasher can two prong, replaced gave me directionals both sides.. DMSFRR thank you for diagrams etc.. John
