Old 03-15-2018, 02:24 PM   #21
JD 1931
JD 1931's Avatar
Default Re: Head Gasket
I used the modern style head gasket for my model a original motor and it worked well, stopped all seepage. Installed it about 8 yrs ago...JD
JD 1931 is offline   Reply With Quote
Old 03-15-2018, 02:37 PM   #22
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by AL in NY View Post
If you use the Best Graphite 509g, Rich Falluca's recommendation is NOT to use any type of sealer, that way the graphite "bonds" to the block and cylinder head metal. Don't know, as I am not a metallurgist, just going by Rich's recommendation and he should be in a position to "know".
As does Charlie Yapp at the Secrets of Speed Society;
"ABOUT HEAD GASKETS:
Our Best Brand head gaskets do not require "sealant" if the decks are flat, near-new, fresh, unscored and clean. Sealant is built into the gasket.
Name goes to up to sky. Start Torque at 25 pounds, using the sketch above, in numerical sequence and increase incrementally 5 pounds at a time to a final torque of 55 pounds."
I have a Snyder's 5.5 on my '30 Town Sedan using a Best 573G gasket. No sealant, no problems.
Old 03-15-2018, 03:27 PM   #23
Flathead
Flathead's Avatar
Pertaining to water droplets at the tailpipe----don't forget that water is a by-product of combustion and some water is perfectly normal.
Flathead is offline   Reply With Quote
Old 03-15-2018, 06:37 PM   #24
Railcarmover
^^^Not only that,^^^ grey iron castings crack...
Railcarmover is offline   Reply With Quote
Old 03-15-2018, 07:45 PM   #25
Smog Tech
Smog Tech's Avatar
Flathead is correct, when you burn gasoline, water is a product of combustion.
The Best website says to use copper spray on their graphite head gaskets. I do and it works well.
Smog Tech is offline   Reply With Quote
Old 03-15-2018, 11:30 PM   #26
denniskliesen
denniskliesen's Avatar
Exactly what I did when installed my 6:1 head over 3,000 miles ago. No leaks, no weeping around the edges. Something AER also recommended at the time was a dab of RTV around the stud at the base of the stud. No coppercoat or anything else for sealer on the surface of the head gasket.
denniskliesen is offline   Reply With Quote
Old 03-16-2018, 08:33 AM   #27
Brendan
Brendan's Avatar
Originally Posted by J Franklin View Post
You are vague about the need to change your gasket. I would agree that you may open up more than you wish if it is not needed.
yup! it took me 3 weeks to get my head off! the studs where stuck to the head
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 03-18-2018, 08:39 PM   #28
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I don’t think anyone sells the 509 G anymore, as it only fits an A. The venders seem to sell the 573, which is for a B with the steam holes. So it will work on either a B or an A. That’s the one recommended for the high compression head.
Old 03-18-2018, 09:11 PM   #29
CT Jack
CT Jack's Avatar
Graphite doesn't bond. It is an excellent high temperature lubricant. If your head is in good condition, flat and not warped, and without cracks I would recommend using a copper gasket. The key to making a Model A gasket not leak is to torque, torque, and retorque the head frequently after installation. Doing this is key to preventing leaking.
CT Jack is offline   Reply With Quote
Old 03-18-2018, 09:54 PM   #30
Synchro909
Synchro909's Avatar
A while back, someone here said they check the tension on the head studs at each service. I have adopted that regime and so far, so good. It only takes a few minutes but a blown gasket can be a real PITA.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-18-2018, 10:05 PM   #31
updraught
updraught's Avatar
The copper ones use graphite.
http://www.bestgasket.com/about_our_products.asp
"GraphTite head gaskets have superb sealing characteristics, excellent torque retention, and hold up to the punishment dished out by high-performance engines"
updraught is offline   Reply With Quote
Old 03-18-2018, 11:27 PM   #32
pbishop
'29er' seems to have covered most everything I could think of and more. Senior Members have those years of experience that cannot be gained any other way.
pbishop is offline   Reply With Quote
