Old 11-03-2017, 01:02 PM   #21
rowens55
rowens55's Avatar
Default Re: E code Air cleaner housing
As I recall ( I can check tonight) those will be to large.
Alive n kickin n mostly kickin!
rowens55 is offline   Reply With Quote
Old 11-03-2017, 01:13 PM   #22
KULTULZ
KULTULZ's Avatar
Just an idea. They were used on a 427 FE COBRA.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 11-03-2017, 01:45 PM   #23
Oldmics
Isnt it Hellings & Stellings for those air cleaners ?
They apparently have been a long time supplier for Ford and Merc preformance parts for quite some time.
I remember that they provided the air cleaners for the 1956 Merc M 260 setup.
Oldmics
Oldmics is offline   Reply With Quote
Old 11-03-2017, 02:32 PM   #24
Milt/Las Vegas
Milt/Las Vegas's Avatar
Oldmics
I wondered if 56 Mercs offered a dual 4 setup.I've seen 56 Merc medalist 2 doors with a stick shift.I think California hiway had some.
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
Old 11-03-2017, 03:51 PM   #25
scicala
scicala's Avatar
'56 Mercury and Ford both offered their own "over the counter" dual quad (260 HP) NASCAR kits. Two different part numbers for the kit. Both kits shared the same one off teapot carbs. Oldmics is the resident expert with part numbers and factory documentation. Never installed on the assembly line. Was not a Police Interceptor thing.
Sal
Old 11-03-2017, 05:10 PM   #26
KULTULZ
KULTULZ's Avatar
Red face Re: E code Air cleaner housing
Made an answering post and posted no info...
This getting old and Advancing CRS is a b!tch-
Below is the M 260 Kit Description...
Last edited by KULTULZ; 12-02-2017 at 10:01 AM. Reason: ADD THE INFO ORIGIONALLY REQUESTED
Old 11-03-2017, 05:12 PM   #27
KULTULZ
KULTULZ's Avatar
Exclamation Re: E code Air cleaner housing
Oldmics
Correct. I slurred my URL...
Old 11-03-2017, 05:17 PM   #28
KULTULZ
KULTULZ's Avatar
Here's another two suppliers-
http://wolkdesign.net/dual4bbl.htm
http://www.obrientruckers.com/ecom/category/239/
Just suggestions.
Old 11-03-2017, 05:43 PM   #29
rowens55
rowens55's Avatar
Not shire how much help this will be. My ECG9424-D intake is 7 7/16" center to center front stud to front std. that leaves 3 15/16" (if my math is correct) rad for each air cleaner. Thus my choice of 2 @ 6 3/8"..think they were (pour memory) about 12 bucks apiece. Bought 2 extra elements and stacked em. I'll try and find the pic. Personally think they look kinda kool.
Old 11-04-2017, 01:42 AM   #30
Alaska Jim
Alaska Jim's Avatar
I want to thank everyone who answered my questions and gave me advise I appreciate all of it. I will take my measurements, and if it will work I will keep looking until I find one, and then see if I can bring myself to cough up the dough, I don't expect it will be cheap. Thank you all.-----Jim
Alaska Jim is offline   Reply With Quote
Old 11-05-2017, 09:50 PM   #31
My Old Blue
Originally Posted by KULTULZ View Post
Thank you for these links. Good options.
My Old Blue is offline   Reply With Quote
Old 11-08-2017, 11:12 AM   #32
Jay in Mass
Originally Posted by Alaska Jim View Post
Milt/Las Vegas, . I have a 2x4 set-up on an Edelbrock manifold with 2 of the 4000 series teapot carbs. I think the center to center of the air cleaner studs are the same as a factory manifold.
I had an aftermarket dual quad Y block intake and the center to center air cleaner studs were NOT the same as factory studs. Had to use a factory dual quad manifold to get the stock dual air cleaner studs to fit.
Jay in Mass is offline   Reply With Quote
Old 11-08-2017, 12:00 PM   #33
Milt/Las Vegas
Originally Posted by dmsfrr View Post
Alaska Jim...
On a facebook Thunderbird page I remember an E-code owner asking for help locating replacement filter elements. Not sure what he ended up using, apparently they are almost as difficult to find as the housing. Just something else to consider....
Dennis
<edit>
Filter elements -
I found the original fb post and copied 3 (unverified) comments below from other folks.
"The Ford specs for these elements are: 5 9/16" ID, 7 1/16" OD, 2 1/8" High with part number: B7A-9601-F ... but no one seems to have anymore. An alternate might be FRAM's 42148 measuring 5 1/16" ID, 6 7/8" OD, 2.150 High. Not the exact size, but possibly close enough to work. At $7 from rockauto I'd give it a try."
http://www.autopartoo.com/oem/fram/ca130pl.html
"here's a link to the K&N filter Brian mentioned"
https://www.knfilters.com/search/product.aspx?prod=e-3320
Height 1.75 in
Inside Diameter 5.25 in
Outside Diameter 6.25 in
Remember the car filters are taller than the t-bird filters.
Milt/Las Vegas
Old 11-08-2017, 02:57 PM   #34
Alaska Jim
Alaska Jim's Avatar
Jay, and Milt. Thank you for the information I appreciate it. I have found the chart that Ted Eaton had posted over on the Y-blocks forever forum, I will try to post it for every one so if this comes up again it will be here for all.
Old 11-08-2017, 03:03 PM   #35
Alaska Jim
Alaska Jim's Avatar
Here are the carb center to center spacings for the various Y dual quad intakes.
Edelbrock FM255 – 8 ¾”
Edelbrock 257 – 7 1/8”
Edmunds DM-427 – 8 9/16”
Mercury ECZ-9424-C – 8 ¾”
1956 Ford EDB-9425-C – 7 5/16”
1957 Ford ECG-9424-D – 7 5/16”
Fenton DM-427 – 8 9/16”
Old 11-08-2017, 05:06 PM   #36
Oldmics
Jim
I have seen that measurement list posted somewhere else, perhaps it was Ted Eatons over on Y Blocks forever.
I am only going to address the measurements on the Ford manifolds.
I"m sticking by my center to center distance of the Holly teapots mounted in REVERSE order as applicable for T Birds as 7 13/32.
Orienting the carbs in a normal fashion in the way the "E" Code passenger cars used them brings a different measurement of 7 7/16 (or 7 14/32)
The hold down wing nut holes in the "E" air cleaners are drilled 3/8 .
So theres a fair amount of room for a 1/32 offset difference in the fit of the air cleaner regardless in the orientation of the carbs.
I know its just splitting hairs on my 1/32 difference measuements BUT it is a fair amount of difference ( 1/8 ) as opposed to the 7 5/16 spec that has been posted.
Now all that being said I"m curious to know - what did your manifold measure out to be and what air filter will you be using ?
Oldmics
Old 11-08-2017, 11:28 PM   #37
Alaska Jim
Alaska Jim's Avatar
Oldmics, the stud to stud distance on my 2x4 set-up measures 7.230 inches. that chart I posted , did come from the Y-Block forever forum, posted by Ted Eaton. I guess for now I will use the "D" shaped air cleaners that I bought from spotlite custom accessories a little over a year ago. I am not completely sure I like the look, I may powder coat them black instead of chrome. the tri-power air cleaners are black, that are on the eng. that is In my car now, as are the manifold, v/c's, and other components, the eng. itself is gold I will try and post a couple of pictures, they are not very good, but will give you an idea what is going on. I guess I will not be using the factory oval air cleaner
Old 11-09-2017, 10:37 AM   #38
KULTULZ
KULTULZ's Avatar
Red face Correction
i captured this photo from a web page supposedly showing an original 1956 MERC Monterey M260 install (AUCTION HOUSE LISTING).
I am pretty sure the element(s) is not correct.
I have a factory kit release correct photo stored somewhere...
EDIT-
CRS AGAIN! Where's The Beef!?!?
The air cleaner is not correct as it is the oval air cleaner (unless two separate kits were issued or this is a real M 260 Factory Build.
The ACL ELEMENTS APPEAR TOO HIGH. Possibly correct replacements couldn't be found...?
Old 11-09-2017, 02:13 PM   #39
Oldmics
Default Re: E code Air cleaner housing / M260
Real item as found
Oldmics
Old 11-09-2017, 02:16 PM   #40
Oldmics
Jim
Thats a might healthy looking Y Block !
Oldmics
