#21 |
The cotter pin is there to keep the hole open, the hole is there to let out any oil that accumulates there.
#22 |
Thank goodness Henry wasn't related to either Harley or Davidson . My 30' VL Harley has a total lost oil system ... I can't complain about my old Ford .....
"I can't cry as long as I know the Lord has risen " |
#23 |
See there, Frank, that's another question!
Alan |
#24 |
I took the damn cotter pin out on my last engine - decided after all these years of looking at them, that I no longer needed too . . . made it easier to paint the pan anyway! LOL
#25 |
I wouldn't remove the cotter pin. It is there to keep the oil drain hole open.
Without it oil mixed with dirt and road gravel would eventually close the hole and over time enough oil could build up for the fly wheel teeth to throw it up into the clutch. The cotter pin is loose so it jiggles to keep the hole open. G.M.
www.fordcollector.com |
#26 |
#27 |
The noise you heard was merely harmless feedback from your hearing aid...Still, you can control this phenomenon by turning down the volume.
Alan |
#28 |
#29 |
I have an old 8N tractor with that same cotter pin in the bottom of the clutch bellhousing - supposed to allow accumulation of moisture and any oil to drip out rather than build up and get on the clutch as I was told.....
#30 |
Old Ford saying"If it ain't leaking,don't crank it up,because there is no oil in it"
#31 | |
![]() Quote:
#32 |
I've been following this thread mainly out of curiosity, since I'm an "8BA guy". I'm wondering : did Ford improve the oil seals enough in going to the 8BA's to be able to eliminate the cotter key? IIRC, they both use similar "rope" seals.
#33 |
The rear seal was improved before the 8ba, but since oil pans were interchangeable between the years of 35 to 48 pass car engines, I'm thinking Ford kept that drain hole up to 48, just for that reason.
#34 | |
![]() Quote:
I think I'll start selling "retrofit cotter keys" for 8BAs, should be able to raise enough Hell on the internet for it to go 'viral' and then everybody will want one! Yeah - that's it . . . my new way to fame and fortune! B&S |
#35 |
It's an oil level indicator like the old Harley's had. When you have parked it for awhile and return... if there is no oil spot under it, it's time to add oil...
#36 | |
![]() Quote:
We all know the answer - and the answer is "No" . . . why would anybody believe that Ford designed it to leak? That makes absolutely no sense at all - what would be the purpose of such a design - I can think of none. It sorta seems like the main point was to mention the diaper you sell -- cool by me -- by letting folks know, maybe you'll sell some to those who have a problem and like your solution. Maybe just make a post that shows your solution, how it is installed, an example on a car, etc. . . . |
#37 |
If you ain't drippin,
You ain't trippin |
#38 | |
![]() Quote:
Alan |
#39 |
#40 |
All four of my running flathead vehicles were built with 'Best Gaskets' sets and I see no leaks on any of them. Only my British stuff leaks.
