Old 10-17-2017, 10:13 AM   #1
pgerhardt
pgerhardt's Avatar
Default Head Questions
No not mine. I already know how that is functioning!! (Actually I really do. After my stroke, I was tested "up the kazoo".)
Snyder's offers two cast iron HC heads; the A-6010HC (5.5:1) and the A-6010HC6(6:1)
Question1:
The 6:1 head is only $10 more than the 5.5to1. My question is why would you not want the 6:1 head, which makes more consistent power over the model A's RPM range? Put another way, what is the down side to the 6:1 head?
Question2:
Are these cast iron HC heads a direct bolt on (without any mods other than using a model B gasket) replacements for the stock head?
Question3:
Are they machined to use the larger model A spark plugs, and can I use my Champion 3X plugs?
pgerhardt is offline   Reply With Quote
