#21 |
Is the intake polished or chrome plated?
#22 |
Why would block off plates be a big concern? It is/was a fairly common practice. No idea where the sand would come from, one guess would be the intake was blasted at some point and not cleaned that well after.
#23 |
Chrome plating can cause hydrogen embrittlement. The sheet metal covers don't look all that thick but they would still have a shim effect that could cause stresses there when the bolts are torqued up. It would't take much of a step there to cause a crack on an old part like that. Especially if its one of the early ones that were kind of frail anyway.
#24 |
The sand is aluminum oxide, IMO.
Just a guess, but moisture from exhaust entered through opening one side combines to make a corrosive mess. I bought an intake from a well known vendor that had a hole between the heat riser portion and the vacuum of the intake. It had a similiar appearance. With that much corrosion, I would replace it. Now Karl |
#25 | |
![]() Quote:
If the manifold is plated, we could probably forget about welding. I thought I learned in school many years ago that hydrogen embrittlement really only affected ferrous metals like steel and iron. Just did a quick search on Wikipedia (which can be wrong) and found the following -- "In tensile tests carried out on several structural metals under high-pressure molecular hydrogen environment, it has been shown that austenitic stainless steels, aluminium (including alloys), copper (including alloys, e.g. beryllium copper) are not susceptible to hydrogen embrittlement along with a few other metals"
Regards - Randy 1933 Tudor |
#26 | |
#27 | |
![]() Quote:
#28 |
i have a nos aftermarket intake brand new shape.150.oo plus ride
