#21 |
If anyone is CONFUSED about the GAV, jist log on & we'll CONFUSE you some MORE--LOL
Chief sed, "When you find its' SWEET SPOT, jist leave it ALONE"!!! Bill Backwards
#22 |
#23 | |
![]() Quote:
In California we do get down into the 30's (degrees) in winter but only rarely into the 20's so cold starts are not really a problem for me. David Serrano |
#24 |
Mine is same as David Serrano.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
#25 |
When cold my car needs to have the choke pulled out to fire then starts immediately once it is released. That's quite normal for any four stroke engine, if they start without any choke they will be running too rich for the rest of the time. You can't argue with common sense.
PS I first tried that way because all the books that I read by Model A experts said that was the way. They were right. |
#26 | |
Fred Kroon 1929 Std Coupe 1929 Huckster |
#27 |
Minerva started with NO CHOKE & wasn't TOO RICH! 12,000 miles & NEVER pulled a plug!---SO THERE!!!--I tole you I wuz GOOD!
Bill Smartass
#28 | |
![]() Quote:
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
#29 |
Thanks for all the reply's. I understand the "features" of carb and ignition now and should be able to work it out. Thanks again.
#30 |
I often would start my '29 coupe with the crank, but needed to make two modifications: A clothespin to hold the rod back for a couple of pulls on the crank; and a wire running from the choke through just beneath the radiator to where the crank was so I could re-open the choke without having to get back into the car and remove the clothespin. Worked every time. Crank starting always impressed the ladies in the college parking lot.
