Old 08-31-2017, 01:12 PM   #21
V8 Bob
V8 Bob's Avatar
Default Re: thermostats
The NAPA 111 stat may work great on early V8s, but is too small in diameter at 1.882" to work on late flatheads, were a diameter of 2.062" is about the minimum. A 170 stat is what I would like to run, but haven't found any to date.
V8 Bob is offline   Reply With Quote
Old 08-31-2017, 01:24 PM   #22
JSeery
JSeery's Avatar
A 180 or 185 would be better.
Old 08-31-2017, 05:20 PM   #23
mhsprecher
mhsprecher's Avatar
The Stant stats are what I got for my truck and are 170's. I think I used Old Henry's recommendation, but didn't need to wire them in. When I get home I will look at the boxes mine came in and share them here. The ones I got from Shewman for my 39 sedan were 180s.
mhsprecher is offline   Reply With Quote
Old 09-01-2017, 08:58 AM   #24
Old Henry
Old Henry's Avatar
Anyone considering Shewman's thermostats may want to check out this road test I did of them: https://www.fordbarn.com/forum/showthread.php?t=143576.
Old 02-05-2018, 07:55 PM   #25
bills
What gage is that wire? Do you trim it so that it stops short of the clamp (so it doesn't leak)?
Thanks!
bills is offline   Reply With Quote
Old 02-06-2018, 12:36 AM   #26
Drbrown
Drbrown's Avatar
I use Stant 160's. The engine runs at 175 degrees anyway; maybe 180 going up a steep hill. I hold the stats in-place with a one-inch high piece of cut radiator hose .... one-size smaller than the actual radiator hose itself. Filler does not inhibit water flow .... its the same inside and outside diameter as the cast iron head outlet on which the stat sits. Little rubber cement holds the rubber filler ring in place; no drilling needed; easy to change stats if needed.
Drbrown is offline   Reply With Quote
Old 02-07-2018, 04:00 PM   #27
Automotive Stud
Automotive Stud's Avatar
If you need a 170 for the earlier motor, use a Beck-Arnley 143-0692 if you can still find them. They work great in two cars I have, they both run right at 170.
Automotive Stud is offline   Reply With Quote
Old 02-07-2018, 05:29 PM   #28
joe plumber
I don't run any in my 53 flathead.When I did it always ran maxed the heat gauge out .Ihave a new radiator and 900 miles on a newly overhauled engine.I believe all one needs is a clean radiator and clean block.Works for me
joe plumber is offline   Reply With Quote
Old 02-07-2018, 07:50 PM   #29
Drbrown
Drbrown's Avatar
Joe Plumber raises a good point. Stats are beneficial to hasten the engine's warm-up. But some Yea and nay of it .... a stat slows the flow of coolant, which MAY allow the coolant to absorb more heat from the block, and yet some here like pumps that speed the flow (????) In my colder climate I vote for stats (of whatever rating) to get my heater working and oil thinned sooner, and a clean block and radiator for max efficiency.
Old 02-08-2018, 09:02 AM   #30
36Bill
36Bill's Avatar
Do these work in a 21 stud '36 engine? I flushed my system and now it runs cool.
The best way to have a friend is to be a friend. Howdy Doody
36Bill is offline   Reply With Quote
Old 02-08-2018, 09:26 AM   #31
Tony, NY
Rock Auto has the Subaru's in many temps and cheap. https://www.rockauto.com/en/catalog/...hermostat,2200
Tony, NY is offline   Reply With Quote
Old 02-08-2018, 09:34 AM   #32
Automotive Stud
Maybe that works in California or wherever, but here in NJ the engine won't get up to operating temperature in the fall and winter months, and in the summer the temperature will creep up in traffic or waiting to get in or out of a car show. Every car for the last 70 years has come with thermostats, I don't see any reason why anyone wouldn't want to use them.
Old 02-08-2018, 11:51 AM   #33
joe plumber
I live in Nebraska.
Old 02-08-2018, 12:01 PM   #34
flatjack9
flatjack9's Avatar
I've got an 8BA in my 39 and I use 180 deg. Stant Superstats #45358. Without them, the temerature barely gets over 150. Not good.
Old 02-19-2018, 05:31 PM   #35
compyello
Would these subaru thermostats be considered high flow?
compyello is offline   Reply With Quote
Old 02-19-2018, 10:33 PM   #36
Otterby
Otterby's Avatar
How were the thermostats held in place originally? Were they a different style? I’m pretty sure it wasn’t with a couple copper wires wedged between the neck and the hose. I haven’t been able to make that work without a small leak where the wire is.
Otterby is offline   Reply With Quote
Old 02-19-2018, 11:16 PM   #37
Karl Wolf
Karl Wolf's Avatar
I run 180 degree thermostats.
Make sure to buy the ones that fail open. (Reverse popet- not many know the term.)
They are more $, well worth it against the price of damage from a closed inoperable one.
Karl
Karl Wolf is offline   Reply With Quote
Old 02-20-2018, 12:37 AM   #38
JSeery
JSeery's Avatar
Older thermostats were a barrel style, completely different. Here is an example of one type.
Old 02-20-2018, 07:28 AM   #39
bills
I had the same problem. I had to cut the wires so that they didn't extend below the bottom of the clamp. It did correct my moving thermostat issue.
I think originally the thermostats were held in place by the way the hoses were molded.
I have seen old, original hoses that narrow just above where the thermostats sit in the head. I'm guessing, but it makes sense to me. The new aftermarket hoses (at least the ones I bought), are the same I.D. from end-to-end, so there's nothing to hold the thermostats in place.
Old 02-20-2018, 07:55 AM   #40
Jim in Wisconsin
Did Ford put thermostats in the early V8s?
Jim in Wisconsin is offline   Reply With Quote
