Old 05-23-2017, 08:25 AM   #21
shark 81
shark 81's Avatar
Default Re: front spring
thanks for all the info barners. I have successfully replaced the center bolt and restacked springs.
looks like the center bolt had been broken for some time causing the leaf stack to shift and droop to the drivers side causing the tie rod and drag like to rub.
shark 81 is offline   Reply With Quote
Old 05-23-2017, 08:34 AM   #22
JDupuis
JDupuis's Avatar
Good job shark 81! Now drive it like you borrowed it from Dad. . Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
