#21 |
15 years without being started on an unknown rebuild requires more than a bit of penetrating oil and a big wrench or hammer.
Remove the head, valve cover, and pan. Then inspect things. After that you can begin using penetrating oil - on the cylinder walls and valve guides. I would also find a way to get oil into the bearings - maybe spin the oil pump with oil in the pan. You have no clue about what the rebuilder did or did not do. |
#22 | |
![]() Quote:
In any case, you would only get oil to the main bearings which could be done by removing the valve cover and squirting some oil down the 3 holes to the mains, OR just put a quart of oil into the valve chamber through the hole the dizzy fits in.
All steel from pedal to wheel |
#23 |
We used to be able to spin the oil pump thru the distributor hole on a Chevy small block with a bar that didn't have the cam gear attached to prelude before starting.
Never did it with an A so I said maybe. |
#24 |
If it were mine, I would not attempt to try to turn the engine over until one quart of oil was poured down the distributor hole. I would use a lighter weight oil, like straight 20 weight. I would also remove all the spark plugs and pour about 1/2 cup or so of ATF/acetone mix down in each cylinder and let it soak for a few days. While you’re waiting, obtain a piece of clean straight wire, about a foot long or so, and insert it down where the dip stick should be and see if there is any oil in the pan. I haven’t measured a dipstick in awhile but I think the length that goes down in is about 8 inches as measured from the hole on the block to the end of the stick when it is fully inserted.
#25 | |
![]() Quote:
Except for the oil pump part.. the mains are gravity fed from the valve chamber and the rods are splash and scoop;; Other things to ck at this point would be the oil feed holes, pump screen, timing gear teeth..... Clearances if your really energetic Then work on freeing it Last edited by Mitch//pa; 12-30-2016 at 08:44 PM. |
#26 |
#27 |
Put it in third gear and try to rock it to get something to break loose. Take the starter out until you figure this out.
#28 |
Great advise guys. I was told the fellow that did the rebuild was well known for his work on the "A" motor's.
#29 | |
![]() Quote:
One afternoon, in 1963, I was managing a Gull gas station and a guy came in and asked me for a tow of his '40 Ford coupe. Earlier that day, on his way to work, he had over heated the flat head V8 motor, and he had left the car along side the road to cool. Now, in the afternoon, the starter would not crank the motor over. I did just what he asked me to do. We got it rolling by towing and he popped the clutch. It skidded the tires a couple of times, and then finally the motor was turning over. The motor was running on about half the cylinders and lot of water was coming out of the exhaust. We checked the oil and the oil level was high with water in it too. What had happened was that he had blown a head gasket earlier and while the car was sitting all day, a couple of cylinders had filled with water. When we towed it, the sudden impact of the water in the cylinders blew a couple of tops of the pistons down into the crank case. What could have been an easy head gasket fix, turned into a motor replacement. I traded him out of the '40 Ford coupe. I wish that I still had it. ![]() |
#30 |
#31 | |
![]() Quote:
I bought a 65 Galaxie 500 that was in a flood in 2008. Car only has 65k miles on it. After the flood from broken levy, and because health issues owner couldn't get back to caring for his car collection. When I first looked at car I pulled dip stick and it was full of water. After pulling plugs, two cylinders had water. I filled those two cylinders with ATF. I drained oil pan and filled with diesel fuel to rinse pan and filled again to soak. What are the chances I would break bolt on crank pulley? Would the grease do the job through a plug hole? I also have a 61 Falcon that was parked in 1985 in a garage and the motor is also stuck. I pulled plugs and have it soaking with ATF. I would like to get these two moving again. |
#32 |
Consider pulling the engine and doing a complete rebuild of what ever you find wrong. You don't know what kind of work (quality) the former owner did. You do know the engine sat in a damp garage for 15 years. The peace of mind should be worth the effort.
#33 | |
![]() Quote:
#34 |
Back in the early eighties a friend found a model T with the same situation you describe but only had sat for ten years. We tried everything. But we came up with a idea to soak the whole motor. 55 gallon drum and filled it with diesel fuel and transmission fluid. There was a transmission shop near by and he had drums full of used fluid. We let it sit for about 2 weeks , pulled it and gave it a try still too stiff but some movement. Another two weeks and it spun over fine. The bonus was everything cleaned up nicely. We made a speedster with the engine and ran great . He sold it about 10 years later.
I should have bought it. Good luck with your engine . Happy New Year
old car guy |
