#21 |
I AM SURE the Navy said, "There's the right way, the wrong way and the Navy way."
#22 |
I was taught that current flow was positive to negative but electron flow was negative to positive.
YMMV
#23 |
Then why in an electrolysis tank does the current flow from negative to positive?
#24 |
#25 | |
![]() Quote:
Mathematically speaking, current may have either a negative or positive value in the physics equations describing electricity and magnetism. When the charged particles are moving in the direction that free positively charged particles would move, it is labeled "positive:" This could be either positively charged particles moving away from positive toward negative in an electric field, or, negatively charged particles moving from negative toward positive. Conversely, "negative" current would be when charged particles are moving toward the same-charged end of an electric field. Positive current is the spontaneous direction, whereas negative current requires an external source of energy to force the particles to move toward their own charge. For example, when the electrons in your car's wiring are moving "downhill", such as when lighting lights, firing spark plugs, cranking the starter motor, etc., "positive" current is said to be flowing. When the battery is being charged, negative current is flowing--even though, in both cases, negatively charged electrons are doing the moving. It's a bit more complicated if you want to talk about what's going on inside the battery. Last edited by steve s; 11-05-2016 at 07:28 PM. |
#26 |
I have found out what happens when + and- electrons run into each other! :-) |
#27 | |
![]() Quote:
In everyday life, where we only deal with normal matter, we never deal with positive, or "+", electrons. Although, they do exist, there basically are no such things as far as everyday life is concerned; if any appeared, they would almost instantly be destroyed as soon they come into contact with ordinary matter. Positive electrons are a form of anti-matter, and are referred to as positrons. They can be briefly created by physicists using synchrotrons and such. I think your confusion comes from the mistaken assumption that positive current can only happen with positively charged particles. |
#28 |
#29 |
I have always used pos to neg in my trouble shooting. Even the schematic drawing of electronic symbols work pos to neg.
#30 |
#31 |
To sum it all up, It's all FM (f'ing magic)
#32 | |
![]() Quote:
Ok, first, remember that the Model A ignition switch does NOT disconnect any of the electrical flow except the Ground to the points! Modern day cars, when you turn off the ignition, you remove the power to the entire car except the 4way flashers(basically). Now, knowing this, you can still turn ON the head lights, tail lights, and anything else that does not have an interrupted circuit from the battery on the Model A. To change from Positive to Negative ground on a Model A it will entail moving the shielded wire from the distributor to the Negative terminal of the Coil, and, using "non-popout" ignition switch, interrupt the Positive juice from the battery to the Positive terminal of the Coil through the ignition switch. You will also need to polarize the generator, but this is easily done by quickly shorting a wire across the input and output terminals of the Cut-out. All the incandescent light bulbs on the car don't care which direction they get the juice from. Now IF you care to build your own LED bulbs or lighting, that DOES care which direction the juice comes from. And before you ask, YES LEDs can be used on a 6v system, BUT the industry hasn't found enough market to make them. Myself, I have changed to 12v Negative ground and built my own LED lighting for my early Drum tail lights because everyone makes LED for the Teacup light, but no one makes LEDs for the drum! That is the short version
New owner of '28 Tudor Previously owned; '30 Sport Coupe '28 left brake ccPickup '31 SW Town Sedan '28 AA Stake Bed '30 Cabriolet '42 Super Deluxe 4door Sedan "If it don't fit, get a bigger hammer. If it breaks...... ya needed a new one anyway!!" Doing a good job here is like wetting your pants in a dark suit. It gives you a warm feeling, but nobody notices. Never pass up a bathroom Never neglect an erection Never trust a fart |
#33 |
As far as the coil, if you switch to negative ground, just swap the 2 primary terminal wires on the coil. This will keep the polarity for the spark plug correct.
Also you'll have to swap the wires on the back of the ammeter. |
#34 |
+ or -, strong spark is where it's at.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
#35 |
