Old 07-05-2016, 09:43 AM   #21
billybronco1
Default Re: Car died will not start
Key off 6 volts both sides of the coil.
Key on points shorted six volts on neg side of coil and .65 on the pos side.
billybronco1 is offline   Reply With Quote
Old 07-05-2016, 09:58 AM   #22
Dick Steinkamp
Dick Steinkamp's Avatar
If "key off" you have 6V on both sides of the coil, then either the ignition switch is bad and still making contact in the off position, in which case you would not be able to turn the car off with the key, OR (hopefully) your have a typo in your post and you really meant "Key ON 6 volts both sides of the coil".
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 07-05-2016, 10:21 AM   #23
billybronco1
Yep 6 volts on both sides of the coil with key off even the switch disconnected.
Old 07-05-2016, 10:23 AM   #24
Mitch//pa
That's normal
Old 07-05-2016, 10:38 AM   #25
billybronco1
Okay guys something no one seemed to think of is a bad condenser - all fixed this was a good learning experience - thanks.
Old 07-05-2016, 12:38 PM   #26
Tom Wesenberg
Tom Wesenberg's Avatar
Normally changing the condenser is the first thing mentioned.
I've never had a coil or condenser fail on my own cars, but those are two spare parts I carry under the seat, as well as a spare fan belt.
Old 07-05-2016, 01:11 PM   #27
cp5491r
cp5491r's Avatar
Same issue for me was a bad switch. It worked fine and then next time I tried to start it, the problem was traced back to a bad switch. Replace it and it was good to go.
cp5491r is offline   Reply With Quote
Old 07-05-2016, 01:22 PM   #28
billybronco1
Ya know I'm not 100% confident its only the condenser - came out after lunch it would not start again thought I burnt out the new condenser so I tried a random one off a boat motor and got spark back. Put the original one in and and no spark. Put the second one back and got spark again. Mean while I was shorting out the key switch, now it runs fine either way jumped key switch or use the key switch. Seems strange I could have a bad condenser and a flaky switch at the seem time, but weird things can happen. If it dies again I will first jump the ignition switch.
Old 07-05-2016, 01:38 PM   #29
Tom Wesenberg
Have you made sure all your connections are clean and tight?
Also a common problem area is the lower plate wire terminal on the points post. That terminal must be located correctly and bent up against the nut, or it can rub on the spring and ground out.
Old 07-05-2016, 02:00 PM   #30
billybronco1
Everything is tight and clean best I can tell, not sure I follow you 100% on the point plate shorting out, all looks good to me.
Old 07-05-2016, 05:04 PM   #31
Tom Wesenberg
The bottom plate has a short multistrand very flexible wire with a flag terminal that is fastened to the bottom of the points pivot/mounting stud. You must tighten the nut then bend the flag terminal against the nut. If you don't bend the terminal up against the nut then it might stick out enough to touch the spring and short to ground.
Old 07-05-2016, 05:13 PM   #32
jthomas6
jthomas6's Avatar
And will drive you batty chasing the problem. Maybe when you move the spark advance a little - it's OK. Go to half advance - dead. Back off a little - OK. Go to 0 advance - dead. It all depends on just where in the circular advance cycle it chooses to short out - then maybe even vibration helps with more intermittent shorts.
If at first you don't succeed, skydiving isn't for you!
You don't need a parachute to skydive, you only need a parachute to skydive twice.
jthomas6 is offline   Reply With Quote
Old 07-05-2016, 08:44 PM   #33
Hook
Hook's Avatar
I just finished chasing something similar for about a year. don't want to bore you with the sad story, but I kept finding things wrong, assume I had found the problem but had not. Each fix made it slightly better, but didn't solve the overall problem.
So, are you using an aftermarket "look alike" pop out switch?
If it is not the original pop out type switch, what type of wire do you have going to the distributor? Mine was small metal sheath with wire in it that would screw in to the distributor.
Is the lower plate in the distributor original? Points original? Upper plate original? Wire from coil to distributor original?
Let me know and I'll share my experience with problems found in most. Mine now starts so quickly I can't believe it.
1930 Pickup in Prior Lake, MN
Hook is offline   Reply With Quote
Old 07-05-2016, 09:02 PM   #34
billybronco1
I would assume mine is a bunch of random parts from here and there I doubt much is original ford stock.
Old 07-05-2016, 09:22 PM   #35
saintjoelarry
Just now catching up on the forum, and saw your post. I think you've received very good advice ...although was also surprised that replacing the condenser was not the very first thing mentioned. Especially with the heat. You can even buy a heat shield to place below your distributor to protect the condenser from the heat.
Definitely check the wiring underneath the points plate. The wire itself could be frayed, as was the one on my 30 Model A. When I would advance the timing after it started, it would stall. Easy fix, simply remove the points cam nut, push down on the points plate (is held in place by spring tension, turn counterclockwise (or was it clockwise?) and the plate pops right out. Check the wire and the fitting at the end.
I also agree with whomever said coils rarely go bad. I get most of my old car advise from my 75 year old father, who was a farmer and grease monkey for much of his life. When I suggested I had a bad coil on my Model A, he said he rarely, if ever, had seen a coil go bad on a 6 volt car or tractor. Not that it can't, just that he couldn't recall seeing it in 60+ years of working on the things.
One more thing to add though is just the wiring in general. If your wiring has not been replaced, then the insulation is definitely flaking off. Go out and buy the replacement wiring from a place like Snyder's. They are cut to length, have correct ends, and correct cloth coating. It will save you a lot of trouble in the long run just to replace them now.
saintjoelarry is offline   Reply With Quote
Old 07-06-2016, 09:40 AM   #36
mshmodela
mshmodela's Avatar
Don't get fooled, a volt meter from ground to the switch side of the coil should show 6V since the meter itself completes the circuit.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-06-2016, 10:23 AM   #37
Dick Steinkamp
Thanks, Mike!
Old 07-06-2016, 10:40 AM   #38
eagle
eagle's Avatar
I'm not saying this to hurt any feeling just giving my input. I troubleshoot equipment for a living and have for almost 30 years. The WORST kind of repair is when someone just starts replacing parts without diagnosing the problem precisely first. Never ever replace a part until you have verified it is bad. Of course, every rule has an exception, sometimes when you have an intermittent issue that will not occur when you are able to diagnose, then some careful replacement of parts is necessary. However, very important to test the new part too. Assuming a part is good just because its new can REALLY get you in a pickle! Another thing that can get you into some deep waters... "I had a similar problem and did this and it fixed it" Just because a particular fix worked on his car usually will be a wild goose chase on yours. Get yourself a GOOD meter, a detailed wiring diagram, and figure it out. You will be much further ahead in the long run, and you will learn your system so next time around it will be easier. Just my two cents.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 07-06-2016, 11:06 AM   #39
Marshall57
I respect you ideas, but disagree. I think that changing out a distributer on a car for a known good one is the best way to start. I find that the search can range from gas to spark and everywhere in between, but most of the problems I find are in the distributer. I have a few that I have rebuilt and have run for a while that are known good. It has saved lots of time when I'm looking at a car and they are insisting that it is a carburetor, and I'm just as sure it isn't a fuel problem. If you change it out and the problem goes away, it will narrow your search for the problem, if it doesn't it will also let you concentrate on the others problems you might have.
I also do this with fuel. I hang a small tank on the radiator rods and bypass anything in the tank or fuel filter, or just bad gas. I also do this for the ignition, there is a bypass sold that is more of a factory hotwire, this takes the complete switch out of the equation.
Gremlins are sometimes hard to ferret out, and elimination of whole problem areas can be of great help when the symptoms are all over the place.
Strangest one lately was on the trip to Loveland an exhaust clamp came loose and the muffler fell. Tried to wire it up and pull off into a stop we were making when it fell. The car would not run. Bolted up the muffler loosely and it just barley ran. Got it tight and it ran fine.
Talked to folks at the meet, and had to face palm when I was told that the engine must be grounding through the muffler and the answer was a ground strap.
Marshall57 is offline   Reply With Quote
Old 07-06-2016, 11:20 AM   #40
Hook
Hook's Avatar
If you have one of these cables running into the distributor, check to make sure the wire inside the metal housing isn't shorted to ground. Mine was shorting in three different spots causing poor starting and intermittent shut down. I used an ohm meter to check it. The new ones are made better and won't cause the shorting over time.
