Old 03-09-2016, 06:53 PM   #21
CarlG
CarlG's Avatar
Default Re: Hood alignment
Save it as a PDF
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-09-2016, 07:36 PM   #22
kenparker
kenparker's Avatar
thanks Carl. Trying to post as a PDF. me tinks dis is gonna work.
kenparker is offline   Reply With Quote
Old 03-09-2016, 07:56 PM   #23
v bogart
v bogart's Avatar
Thank You Ken for taking the time to post this . It is exactly what I wanted to see. Vernon
v bogart is offline   Reply With Quote
Old 03-09-2016, 09:23 PM   #24
Tim Armstrong
Tim Armstrong's Avatar
I used a long 4x4 square tube about 12 ft. long. Chain the rear of the frame at rear cross member and I took the front fenders off to chain the front of the frame. I used a bottle jack at the rear motor mount on the bottom of the frame, jack it up till the hood fits. I found tis to be quick and easy in my garage.
Tim Armstrong is offline   Reply With Quote
Old 03-10-2016, 06:45 AM   #25
ron103140
I seem to have a bent frame also and want to know if any of the ideas to correct it can be done with the body on or does it need to come off. Ron
ron103140 is offline   Reply With Quote
Old 03-10-2016, 07:06 AM   #26
Terry, NJ
Terry, NJ's Avatar
I chained mine down to a large flatbed trailer to do some work to it. Then I've heard of chaining it down to abandoned train tracks. But again, These are another version of the cold Re-bending. The metal has been in tension for eighty years. Think of how you break a wire, first you bend it one way, then you bend it back. This "Fatigues" the metal and weakens it. just my humble opinion.
Terry
Terry, NJ is offline   Reply With Quote
Old 03-10-2016, 06:36 PM   #27
duke36
Has anyone tried wrapping chain around platform channels (with body on car) of a 9000# 4 post car lift ? One would think the channels would be strong enough ?
duke36 is offline   Reply With Quote
Old 03-10-2016, 06:58 PM   #28
ed thibodeau
I used a couple of 2X10s on edge(a notch in the bottom for the chain) and it worked fine.
ed thibodeau is offline   Reply With Quote
Old 03-10-2016, 11:54 PM   #29
dave11
Ken
Sent u a private message.
DaveEeddie
dave11 is offline   Reply With Quote
Old 03-12-2016, 12:05 PM   #30
duke36
Ed: In post 28, how are the two 2 x10's placed? Are they laminated to make a 4 x 10 length wise ,set parallel to frame ? Also, with the body on the car, what should be done with the body to frame bolts (loosen some or all of them , etc. ) ?? It would also seem that anything attached to the firewall and radiator (radiator rods, etc.) should be loosened.
