Old 10-12-2015, 06:58 AM   #21
tubman
tubman's Avatar
Default Re: Engine builders - a little advice please
Originally Posted by Diavolo View Post
Just a thought but what if all the oil drained out of the pump and it can't prime? Could pull the cover off and cram some grease in the pump, also check for engagement into the idler gear to the cam.
I had flow out of the pump (it made quite a mess on the shop floor when I removed the line to the filter to check it), but no pressure; I could hold the pressure in with my finger. The pump's coming out today.
Old 10-12-2015, 02:17 PM   #22
Bluebell
My guess is that flatheadmurre is onto it. A rusted spring or oil pressure has pushed the relief open and it stuck there.
If it's the cam gear, then it has to be caused by by something like the pump not turning.
Moisture or acids in the oil, plus time, have done something.
Bluebell is offline   Reply With Quote
Old 10-21-2015, 10:37 AM   #23
tubman
tubman's Avatar
I pulled the oil pump out a couple of days ago and took it apart. It was clean as a whistle inside, and the relief valve and spring looked great. There was some gunk in the pickup screen, but I don't think it would be enough to make a difference. I "Plasti-gaged" the clearance between the bottom plate and the gears and got .003" (factory specs are .0015" to .006"). I had ordered a new pump for the 258" I am building and it feels about the same as the existing pump; about the same effort to turn and the same "slack" in the gears. I'm going to put the new pump in the Merc and mount it back on the engine stand and try it that way. I also have another oil pressure gauge to try and have a new pickup screen. I pulled the plate off the back of the engine and all the gears and everything look fine. The only thing I haven't done is pull the timing cover and cam gear to check to see if there is a problem with the gallery plug. I didn't want to take too much apart on this engine if I could help it, as the front of the engine has obviously never been apart. If I don't get any pressure with the new pump, I guess that would be next.
Wish me luck and stay tuned.
Old 10-21-2015, 02:29 PM   #24
scooder
Got me fingers crossed for you tub.
It's a bugger that you didn't find a good reason for the lack of pressure.
Martin.
scooder is offline   Reply With Quote
Old 10-21-2015, 04:50 PM   #25
tubman
tubman's Avatar
Thanks Martin, I'm hoping it's 6 volts and a bad gauge. Or as others have said, maybe I'm overthinking it. With the good compression and the condition of the bearings and crank surfaces, I just don't want to take any chances.
