#1 |
Since the switch attaches to the shifter, it should be easy to install with no trans in the car.
#2 |
Yes, that's another reason I'm making the change, much more room to work. The car originally was equipped with a manual transmission so I think the PO did some "custom" work to install the original switch. The wires are all taped up and there is not much slack to work with. I think I will cut the wires near the old switch and splice to the wires on the new switch and hope for the best. I'm guessing the original wires do not have any connectors like the new switch has, so they won't do me any good anyway.
#3 | |
Before cutting anything, check out the connections on both. Maybe easier than you think.
#4 |
Well, I think I got it all done today. Man is it hard working with little short wires. I won't know for sure until I get it all back together and can try it. Or should I hook up the battery and test it at the solenoid?
#5 |
If you want to test it to prove the unit is ok or adjusted correctly, just run a battery wire to one of the NSS wires, put it in gear and use a test light on the other wire. The test light should only light up in neutral (or park and neutral if it's been modified).
#6 |
Paul, that sounds like a good way to test if it's working. Will try to remember that. |
#7 | |
I don't get the discussion about start in neutral or park. One of my cars fitted with a Lokar shifter and Fordomatic starts in neutral and park, the other with FMX starts only in neutral.
Personally I wouldn't bother changing the switch. Some years back I bought a 58 switch to change over to park and neutral start but the switch turned out to be the earlier neutral only in a 58 box. Cost me just under $100 by the time I got it and now I just can't be bothered.
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
#8 | |
![]() Quote:
#9 |
The dealer issued '57 Ford car owners manuals said "place gear select lever in neutral" to start cars equipped with Ford-O-Matic. They did it this way because they didn't want the owner to have to shift from park to reverse to neutral while the engine was running if they had designed it to start in park. There may have been a fear that shifting into reverse with engine running while auto-choke was engaged might cause premature wear or damage to reverse gear.
#10 |
How can both be correct. One says 56, the other 57.
