Old 05-01-2015, 09:52 AM   #1
FrankWest
FrankWest's Avatar
Default Re: Naphtha for cleaning carbs and fuel pumps
Originally Posted by corvette8n View Post
I have used toilet bowl cleaner for the outside of the carb only, the old fashioned strong stuff, just don't leave it on too long as your carb will disappear. It makes it look factory new.
I must have ammonia in it. AMMONIA IS VERY caustic..and it will dissolve aluminum and some other metals.
Is the fuel pump body made out of aluminum ? Looks like it or a pot metal of some sort.
FrankWest is offline   Reply With Quote
Old 09-16-2021, 07:58 PM   #2
cadillac512
cadillac512's Avatar
If you have gummy sticky brown residue from old evaporated gasoline,acetone is far better than most other "thinner type" liquids.
Marko39 mentioned the same, as well as the "Gunk" brand cold soak cleaner...it is great for carbs and is what we used in the past for carb rebuilds in the shops.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 05-01-2015, 01:55 PM   #3
DavidG
DavidG's Avatar
Zinc die castings (upper and lower bodies), brass, and steel are the materials used in the construction of the pump. No aluminum was used.
Old 09-16-2021, 06:56 AM   #4
Charlie ny
Ultra sound with heat, 95% water 5% TOP JOB or what ever BJ's has on sale. 20
years ago mine was $700. 8 to 10 hours, even frees up stuck throttle shafts (sometimes).
minimal tooth pick and brushing still req'd. Blowout with various wands & final swish in laq thnr.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 09-16-2021, 07:27 AM   #5
marko39
i have a gallon of carb cleaner made by Gunk. Comes with a basket and works well but may not be available in all states. second best is acetone.
marko39 is offline   Reply With Quote
Old 09-16-2021, 07:52 AM   #6
big job
big job's Avatar
I still use lacquer thinner and brush good soak. then blow it out the its sprayed with
aluminum brightener then wash with water blow out. If this was bad truckers wouldn't
use it ......
big job is offline   Reply With Quote
Old 09-16-2021, 08:30 AM   #7
Los_Control
I watch a youtube channel Mustie1, first time was when searching for some help with a riding lawn mower problem.
But he works on all kinds of old junk, cars, diesel tractors, boat motors etc...
He uses a ultrasonic cleaner and has tried many different soaps and concoctions for a cleaning solution. Couple years later and simply uses Berrymans carburetor cleaner in it now.
Another vote for the ultrasonic cleaner from me
Los_Control is offline   Reply With Quote
