Old 03-25-2015, 10:50 PM   #1
Old Henry
Old Henry's Avatar
Default How to calibrate oil pressure gauge?
I'm tired of my stock dash gauge reading so much lower than my mechanical gauge. I took the gauge mechanism out and see two adjustments inside that can be made. Has anyone every adjusted that gauge and know how? Here's the inside:
You can see two sets of teeth overlapping a hole at 1:00 and 8:00. Which do I adjust and which way?
