#1 |
We always used about .001/inch for cast pistons. Kieth Black's can run a little tighter, especially in aluminum blocks. Forged pistons got about .0015/in when I did them many years ago in race engines. What we did then was crude compared to what is done today. Ron W
PS Too loose will run, too tight won't! Last edited by Ron W; 03-10-2015 at 07:33 PM. Reason: PS |
#2 |
#3 |
I remember reading --I think Murry Fahnstock --that the model a piston could run at .001 tight, I looked in the service bulletins and found-- on page 455--"In production pistons are now fitted to cylinders with a clearance of .0005 to .0025" --so even the model A was designed to run tight piston clearance
#4 |
I would have to look back in my records I do not remember I do remember they were new but around 20 years old. I believe I was told new pistons do not swell as much.
#5 |
Page204 of Service Bulletins calls for loose on .002 and tight on .004. Ron W
#6 |
the clearance. Those Keith Black pistons are amazing, they don't grow much. When they were first coming out with them they gave us pistons to play with. We ran them all over the board, first loose, they were ok at .003 but started making noise at .0035 and they didn't quiet down when they warmed up. Then we kept making them tighter and tighter they really seem to like .001 to .0015 and thats in a race motor. I took a while to figure out that the top ring needed a lot more clearance and thats how they run them now. They are strong also, one motor dropped a valve and it when right through the piston leaving a round hole, dropping the valve into the crankcase. The rest of the piston was intact with the rings still on it still going up and down. Another motor lost a radiator hose and got so hot it seized up when the driver lifted his foot off the gas. After the car cooled down it was started back up and the pistons didn't make any noise. When the motor was torn down later there were no scuff marks on the pistons. These were in at .0025 There is a Keith Black 283 piston that fits and a hemi piston that also fits a Model A Motor. So have fun and clearance is your friend....... |
