Old 02-17-2015, 03:59 PM   #21
Willie Krash
Willie Krash's Avatar
Default Re: Worried!
2 qts in a 12 qt system should be OK to 19°.
My T is in an unheated shop and the antifreeze is in a bucket. It's 70° in Southern Oregon today.
If you added 50/50, a gal should have 2 qts antifreeze. If you've only dropped to 27° you should be OK.
https://www.fcsdchemicalsandlubrican...f/ethylene.pdf
Now you can get a good nights sleep.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 02-17-2015, 04:34 PM   #22
Archie Cheda
Archie Cheda's Avatar
Originally Posted by Tom Wesenberg
. . . Running an engine for 10 minutes is doing the engine harm. You're filling the engine and exhaust with condensation. That's exactly how I locked up two engines back in the 70's. That was a costly lesson.
If you want to avoid the problem Tom describes, put a tablespoon of oil down each spark plug hole (now) and turn the engine over a few times with the hand crank, spreading the oil over the cylinder walls. Instead of starting the engine, just turn it over a few times with the hand crank. If you trickle charge the battery, you could use the electric starter.
I say "now" above, because some of the moisture that condensed in the engine from your short runnings is working to rust the rings to the cylinder walls. The last thing you want three months from now is a stuck engine.
Archie
Archie Cheda is offline   Reply With Quote
Old 02-17-2015, 04:59 PM   #23
Synchro909
Synchro909's Avatar
Fascinating post! Nobody here uses antifreeze, only a little soluble oil for the sake of the water pump maybe. Thank goodness I don't live in such a hostile environment.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 02-17-2015, 05:01 PM   #24
Tom Cavallaro
Tom Cavallaro's Avatar
Ok, thanks....I never noticed the 50-50 before, I always bought the regular and put the gallon in and add the rest with water....I paid 23.00 dollars for it so I assumed it was what I used to buy.....never thinking it was watered down! Now you guys don't like the light bulb in there either?
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong.
Tom Cavallaro is offline   Reply With Quote
Old 02-17-2015, 05:14 PM   #25
Joe K
Joe K's Avatar
Originally Posted by 31 Model A View Post
From reading above, I guess letting your A sit in a cold garage and then warming the garage up to do work, creating condensation on the engine and almost everything else is not good either. I have wondered about this when I would heat up the garage to do some things.
If you warm the garage up without introducing moisture by use of a vented heater, by heating the air you're reducing the relative humidity in the garage. And decreasing the possibility of condensation.
If it wasn't condensing before heating the air, then it won't be condensing once the air is warm.
If you use an unvented heater, such as many gas radiant or portable kero units, part of the combustion products of these is water vapor which MAY create an issue of condensation on cold metal parts.
No, correction WILL create an issue of condensation. You'll notice it first on those parts farthest from the heater which remain cold, but are exposed to the warm and humid air.
Of course by the presence of you yourself in the garage, you're introducing moisture through transpiration from your moist little body. However, the decrease in relative humidity by heating the air probably far exceeds your puny transpiration.
Joe K
Shudda kept the horse.
Joe K is online now   Reply With Quote
Old 02-17-2015, 05:23 PM   #26
Fred
50/50 Is so they can charge you more for water and save you the time of making it 50/50...
Fred is offline   Reply With Quote
Old 02-17-2015, 05:31 PM   #27
Mitch//pa
no i dont like the light bulb... what if fuel started leaking one drop will cause an explosion. the bulb wont stop the motor from freezing...
Old 02-17-2015, 05:31 PM   #28
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Joe K
No problem there, I use deodorant..........
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 02-17-2015, 05:36 PM   #29
billwill
Tom is right you or doing more harm than go good luck
billwill is offline   Reply With Quote
Old 02-17-2015, 05:42 PM   #30
mshmodela
mshmodela's Avatar
True, but if you do the math, you'll see 100% pure is much cheaper --your dime.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 02-17-2015, 05:44 PM   #31
Fred
What ??
Old 02-17-2015, 06:21 PM   #32
Tom Wesenberg
Tom Wesenberg's Avatar
I've seen some high priced antifreeze, but nowhere near $23.00 for 2 quarts of it and 2 quarts of water.
Old 02-17-2015, 06:26 PM   #33
CarlG
CarlG's Avatar
Last time I priced it at NAPA, 50/50 was right at half the price of 100%, so it was/is really just a convenience thing.
Having said that, NAPA isn't the place to buy the stuff anyway. If you are looking for "cheap", WalMart or even Krogers have the same name brands for quite a bit less money.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-17-2015, 06:44 PM   #34
1931 flamingo
1931 flamingo's Avatar
Dusty: Are you sure??
Paul
Old 02-17-2015, 06:53 PM   #35
Gold Digger
I may mix my antifreeze a little strong, 2 gallons of 100% Preston and the rest water in all my "A's". Never look back or worry. They run cool, never lime up, or freeze. I remember my Dad always worrying and fretting about whether he had enough antifreeze in the vehicle to keep it from freezing. I remember his old Chevy froze up and busted the head once, and he was always having the radiator freeze up while driving down the road because he never got the freezing point below the coldest the thermometers read in our area. When he was good for -10* and it was probable -5* the fan drawing cold air through the radiator it must have been -30* and always froze up and blew all the water out. I never did get it across to him what was happening. That's why I always go strong on antifreeze and save on heads and blocks and troubles on the road.
Gold Digger is offline   Reply With Quote
Old 02-17-2015, 06:56 PM   #36
BlueSunoco
What ??
The 100% is priced a dollar below the 50/50 mix per gallon around here. 50/50 mix is half water. So, you are paying twice the money for the antifreeze.
Or put another way, buy a gallon of 100% antifreeze, cut it in half with a gallon of distilled water, and you have two gallons for what you paid for one gallon of 50/50. The math 'don't' lie.
BlueSunoco is offline   Reply With Quote
Old 02-17-2015, 07:36 PM   #37
edmondclinton
Ethylene Glycol anti-freeze, traditional Prestone, recommends a 50/50 mix for all but the coldest conditions possible. The 50/50 mix however is good for -34 F.
Consequently, they sell the 50/50 premix because it is what they recommend and it also makes it easy for the modern day imbecile to use, assuming of course that no water has been added to their radiator and it was previously mixed at 50/50.
edmondclinton is offline   Reply With Quote
Old 02-17-2015, 07:38 PM   #38
clo2jim
clo2jim's Avatar
Take it from somebody that lives in Northern Ontario and had already experienced -30°F weather this winter already and -61° F in the winter of 1982, and using the chart below - you will have no problems with a 50/50 mixture of antifreeze to water. In the winter of 1982 when I experience -62°F (-52°C) I was using a mixture of 60-65% antifreeze to water and had no issues.
In fact a mixture of 70% antifreeze to 30% water will protect down to -72°F.
On the other hand, a 100 percent antifreeze solution (no water mixed in) has a freezing point of only 10 degrees F. above ZERO, it could turn to pure slush when outdoor temperatures drop lower than that.
So it is always better to mix water with the antifreeze - use the guidelines in the table below -a 50/50 mixtures is probably the best to use - This will also increase the boiling point of the solution and you will have less likelihood of boiling over in the summer especially in the south. In fact any new car purchased will come with an antifreeze/water mixture which is optimum to the car. Just refer to your owners manual with your modern vehicle.
FREEZING POINTS FOR SOLUTIONS OF ETHYLENE GLYCOL
GLYCOL % BY VOLUME Freezing Point °F °C
12.5% 25°F -4°C
17% 20°F -7°C
25% 10°F -12°C
32.5% 0°F -18°C
38.5% -10°F -23°C
44% -20°F -29°C
49% -30°F -34°C
52.5% -40°F -40°C
70% -72°F -58°C
clo2jim is offline   Reply With Quote
Old 02-17-2015, 07:55 PM   #39
clo2jim
clo2jim's Avatar
Back in 1982 when I experienced -62°F or -52°C, I had no difficulty starting my car. Of course it was equipped with a block heater and battery blanket. It was one of the few vehicles that started in my town of 2500 people. The car was just very stiff to get moving and very hard to shift the manual transmission - I was driving a 1974 AMC Hornet at the time
Old 02-17-2015, 08:07 PM   #40
Y-Blockhead
Y-Blockhead's Avatar
Wow, really?? I just bought a gallon of Peak at O'Reilly's for 12.99.
http://www.oreillyauto.com/site/c/de...ord=antifreeze
