#21 | |
![]() Quote:
At .022 you would have increased the recommended gap by 50%, gaining nothing but a little more leakage through the ring gap. Bill |
#22 | |
![]() Quote:
I'm wondering what you meant by "seems pretty tight"? |
#23 |
Curious if minimum piston clearance has been exceeded since it is sleeved.
#24 |
How might that happen?
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
#25 |
Yes, Tom. That is what I expected and experienced. My trouble is that when it is stopped and turned off after a drive of, say, 30 minutes at 35 mph, if I try to start it immediately after shutoff, it frequently will just grunt, not turn over, and I can't turn it by hand. When cold it can be cranked by hand or starter like normal for a new rebuild with 1800 miles on it. Stiff, but not unduly so. I had hoped that since my initial breakin at 500 miles that it would hace loosened up and this problem would have gone away. It hasn't, so here I am. I will take some photos later and post them.
#26 |
#27 |
Unlikely. The shop that sleeved and honed the block has a high and long-established reputation.
#28 | |
![]() Quote:
I am in no way a model A engine expert, so all of this might be for moot. |
#29 | |
![]() Quote:
#30 | |
![]() Quote:
Once bought a '26 Chev, that had been re-ringed, if run OVER 50 MPH, for only 1/2 mile, it would SEIZE & engine would STOP. I would coast in neutral, down to 10 MPH, kick it in gear to start it & it ran perfect if held to 50MPH! I just drove it "easy" & in time, as the rings settled/wore in, and it became normal. With any new engine/overhauled engine, just drive it EASY & with CARE, until everything settles in/laps in & you'll be set to go! AND, don't do some "WEIRD" procedure to "seat" in the rings, the rings WILL do what they are designed to DO! As for ring gaps, do what the instructions say, for THAT PARTICULAR SET OF RINGS!----------Is READING a LOST ART? Just like when your wallpaper hanging goes to CRAP, you probably DIDN'T read the instructions, for THAT PARTICULAR WALLPAPER! Bill W.
#31 |
Here are some photos of my condition. The vertical lines may be scoring, but they are so slight I am not able to feel them with a fingernail. The cylinder walls are shiny, and what appears to be discoloration is merely the reflection of carbon on the piston heads.
#32 |
With only 1500 miles I would have expected to see a nice crosshatch pattern yet.
The crosshatch was still visible on my dad's 1970 Pontiac 400 engine with over 100,000 miles, and the engine was spotless inside. I would remove the pistons and fit the rings to the cylinders to check the gaps. Also measure the piston clearance. Also make sure the water jacket is spotless clean. Rust and junk likes to build up in the rear by #3 and #4. |
#33 |
A couple more photos.
#34 | |
![]() Quote:
#35 |
Could be the piston clearance is just a tad bit on the tight side so when up to running temperature, the pistons have expanded just enough to be at or near zero clearance. Let's assume we still have an oil film on the cylinder walls for just enough lubrication to prevent scoring but at shut down, the pistons squeeze the oil off the cylinder walls. Now the pistons are tight against the cylinder walls without that oil film, so the engine won't turn until the pistons cool down and contract.
For this to happen, you must be right on the ragged edge of seizing the pistons in the bores! |
#36 |
As long as you're this far into it have you re-checked brg clearances?? I can't see how ring clrncs could cause your problem.
Paul in CT |
#37 |
Paul, that is on the agenda. Thanks.
#38 |
You say you can't feel them with your fingernails. From what I see, if they're IRON rings, this may be "normal" until the ring surfaces polish over & those marks "may" go away.
IF, the marks were from pistons too tight, you should see, almost like ALUJIMUM like deposits in the marks. I'd just drive it & DON'T WURRY! BUT, WHUT DO I KNOW--------------?????????????????????--(The Dorg's SMILIN') Bill W.
#39 |
looks like it is passing some oil the way the carbon is washed away in some areas of the piston
can you rock the pistons any in the bore---left to right |
#40 | |
![]() Quote:
Even though I may have missed it on the packaging, I see that Snyders specifies that Hastings suggests that their top and middle rings be gapped at .012-.022. Since I gapped mine at .012-.014, I'm at the low end. More and more, with Barner suggestions and other data gathered, I'm settling on just increasing the ring gaps.
