Old 04-13-2017, 03:23 PM   #21
DennisR
DennisR's Avatar
Default Re: tubular rivet tool UPDATE
Originally Posted by Mitch//pa View Post
Here is a pic of the tool with the 5/32 die installed
I have a couple of these hanging around, do you think they would do the same job if I could get hold of the dies and modify the clamp ?
Love a Lot, Trust a Few
Always Paddle Your Own Canoe
DennisR is offline   Reply With Quote
Old 04-13-2017, 05:42 PM   #22
1931 flamingo
1931 flamingo's Avatar
Me, I used little machine screws/nuts, painted the heads black and even with the hood open you can't see how it's fastened.
Not up to Mitch's standards, but cheap and effective for a driver.
Paul in CT
Old 04-13-2017, 06:00 PM   #23
30blutudor
30blutudor's Avatar
Here's the tool I found works great for tubular rivets. Can't do the hood on the car but I've done plenty off. Picked it up a few years back at a swap meet. Works great for brakes too! 😀
Sent from my XT1635-01 using Tapatalk
30blutudor is offline   Reply With Quote
Old 04-13-2017, 06:28 PM   #24
Mitch//pa
Dennis
You can just buy the dies ..it should work fine if they fit on the ends...is there a name on your c-clamp??
Old 04-13-2017, 07:30 PM   #25
Mitch//pa
Dennis
Here is one link to the dies for my tool.. theis place seems pricey but maybe you can search for something cheaper... just a lead to get you going.. they sell the dies separately
http://tubularrivetclincher.yolasite...tegory=2216613
Old 04-13-2017, 08:14 PM   #26
2manycars
2manycars's Avatar
I have one of those old brake rivet tools, and have used it often to install hood bumpers and corner leathers.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 04-14-2017, 01:42 AM   #27
DennisR
DennisR's Avatar
Dennis
Thanks Mitch, no name on the clamp...........
Old 04-14-2017, 10:38 AM   #28
Dan Partain
Dan Partain's Avatar
The links in my post above don't work anymore, here's a view of the rivet and tool that shows the rolled rivet.
Dan Partain is offline   Reply With Quote
Old 04-14-2017, 06:13 PM   #29
captndan
captndan's Avatar
OK, make it easy. I only have two rivets to put in. What should I use?
captndan is offline   Reply With Quote
Old 04-14-2017, 07:13 PM   #30
taffrail
taffrail's Avatar
For two rivets, a cheep C clamp and ball bearing, some of the cheeper clamps have a depression on the screw that you can set the ball in. tap the end of the screw while tightening. good luck
taffrail is offline   Reply With Quote
