Old 05-31-2014, 07:27 PM   #21
Relvis P. Johnson
Default Re: Bass Ackwards?
25 amp fuses, lots of 'em...
Relvis P. Johnson is offline   Reply With Quote
Old 05-31-2014, 07:40 PM   #22
MAG
MAG's Avatar
That should work.
You're sure it is not a 2.5amp!
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 05-31-2014, 08:13 PM   #23
Pilotdave
Pilotdave's Avatar
Hmmm - if the coil is shorted internally, couldn't one detect this by disconnecting wires from both + and - terminals and testing across the two terminals with an ohmmeter? If the coil is shorted, wouldn't the meter read 0?
Pilotdave is offline   Reply With Quote
Old 05-31-2014, 08:17 PM   #24
Tom Wesenberg
Tom Wesenberg's Avatar
Yes.
Old 05-31-2014, 08:22 PM   #25
MAG
MAG's Avatar
Ditto on the YES
Old 05-31-2014, 08:24 PM   #26
JackA
JackA's Avatar
If one is blowing a lot of fuses, he could avoid that by wiring a 6 or 12 volt lamp where the fuse goes. If you have a short, the lamp will light. Saves money.
JackA is offline   Reply With Quote
Old 05-31-2014, 09:25 PM   #27
MAG
MAG's Avatar
Yes this is true but there can be misleading conditions present.
For discussion purposes lets say Relvis has two coils wired in parallel. If one coil is shorted the bulb will shine brightly or full brilliance. If the shorted coil is removed from the circuit the light will still be ON but at a reduced brightness.
The brightness would be determined by the resistance of the remaining coil.
Yes this is a good tool to use when searching for a short but you have to be aware that there could be a parallel resistance in the circuit.
Old 05-31-2014, 11:24 PM   #28
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by Relvis P. Johnson View Post
Now there is a drawing I can comprehend! I'm set up like Bob's drawing, points are closed and the top plate is charged. If I put it in the body, the fuse blows...
You have to have a shorted coil or the wiring is not like the drawing.
Old 05-31-2014, 11:44 PM   #29
Relvis P. Johnson
Problem Solved!
If the wires are hooked up wrong, one can't expect it to work right.
The Bratton's Schematic did the trick.
THANK YOU EVERYONE!!!
Old 06-01-2014, 11:36 AM   #30
Bob C
Great news. What wires were wrong?
Bob
Old 06-02-2014, 11:15 AM   #31
Relvis P. Johnson
I had the junction box wired to the coil. I'll never jump in to such a project without proper documentation again.
Thanks for all of your help!
Old 06-02-2014, 11:19 AM   #32
Bob C
There should be one wire from the coil to the junction box.
Bob
