#21 |
Gary has it right in reply #20. By a couple of the replies I had the feeling that some thought the 20 inch pounds of force was the tightening torque on the 2 nuts rather than the turning torque of the pinion gear.
I just noticed the title of this thread could be what's misleading some to think the torque is on the tightening torque on the nuts rather than the turning torque of the driveshaft. Last edited by Tom Wesenberg; 04-05-2014 at 07:15 AM. |
#22 |
I turned a block of wood in lathe that fit the pinion shaft, then put screws through sides to lock it to shaft, before that cut square hole to fit 1/4 drive inch pound torque wrench...it worked great and I set mine at 15 inch pounds...have to be very careful turning wrench or it clicks...
The only thing worth learning is what you learn after you know it all !! ![]() |
#23 | |
![]() Quote:
Last edited by Purdy Swoft; 04-05-2014 at 09:22 AM. Reason: re worded a sentence |
#24 |
Yes, the nuts should be quite tight. I used a plasma cutter, sanding belt, and files to make these two wrenches for working on the pinion nuts. When you tighten the first nut against the pinion bearing to set the preload, then tighten the second nut against the first nut and washer, you will add slightly to the preload. If you run the second nut up to the first nut and washer finger tight, then tighten the first nut against the second nut (second nut stays still and first nut is loosened), you will loose a bit of preload. So as I tighten the two nuts I start with the bearing preload on the light side, then when the second nut is tightened against the first nut the preload will be correct.
Are we totally confused yet? ![]() |
#25 | |
![]() Quote:
I borrowed a 1/4 inch drive "Snap On" brand inch pound torque wrench from a friend and then went to Harbor Freight and bought one of theirs for less than $10. To my surprise both wrenches gave the exact same reading at 20 inch pounds (new bearings). |
#26 |
Congrats for getting IT done ![]() For the next time...I want to let you know what an old timer showed me as I watched him do this work. Super simple: He wrapped a rope around the shaft. Then he tied the rope onto a inch/lb scale the he held in his hand. Then he pulled/adjusted until he got the necessary inch lb reading. Smartest model A guy I ever met...after Jim b ![]() |
