#21 |
Interesting the front of the engine lines up but the belt wont fit is the space provided. Yea, you have to lift the engine by loosening things up as mentioned.
#22 |
Bought a new B42 gates belt today. Napa couldn't match up the numbers of the one I had.
The new belt is the same length and width...not quite as thick since it's new and the old one was worn/frayed some. Once the weather gets warmer, I'll push out the car and work on it. I'll clean under the engine pulley area first as it was dirty. Then I'll try the install using the methods suggested and let you know. I had another suggestion to use the engine crank to lift the engine some. I.E. put it in the engine pulley and push down and have the engine end lift up (see-saw). Marc |
#23 |
When I have to get the fan belt off I remove the generator pulley and that makes it easy for me.
#24 |
I remove the generator pulley to install the belt too. Marc is running an alternator.
#25 |
#26 |
The doors to my storage shed are blocked with about 6 inches of frozen snow. As soon as I can get them open, I will provide the info on the fan belt I use on my A's. Regards, Bill Lee/Virginia Peninsula |
#27 |
Marc, I've always used a Gates 749 belt (TR22434) is the new number. Every since I put the Alt on I've used this belt.
#28 |
![]() Here's what I've used for years |
#29 |
#30 |
Since the generator has the least belt contact, the belt should go over the crank and water pump first, then finish with the generator. As mentioned, the new aluminum fan isn't quite as wide as the stock steel hub, so the belt rides a little higher on the fan. A belt 1" long might be needed.
#31 |
Chuck Norris could theater the belt and it would install itself.
#32 |
I wonder if you could HEAT the belt to encourage stretching?
#33 |
