#1 |
If your new to the Model A world, make sure you understand how to use the spark advance lever. Fully UP for starting, DOWN for running. The Down position takes some adjustment to depending on where the previous owner set the timing and where your individual engine like to run. For cruising, mine likes to be 2 clicks from the bottom. GAV valve is the carb adjustment on the choke lever, mine likes to be 1/4 turn on until warmed up, then nearly off for highway. Around town open it up to nearly 1/4. To facilitate easier/smoother shifting, make sure you keep the engine idle speed low, then shift early and slow. Meaning don't rev the car AT ALL, shift before you think you should and also shift out of gear, wait a couple seconds, then slide it into the next gear. You maybe know all this, just trying to help in case you aren't aware...
#2 | |
![]() Quote:
Shane Henderson Baileigh Industrial [email protected] www.baileighindustrial.com 920-482-3220 Metal Shaping Heaven www.baileighindustrial.com Click Here For Serious Metal Fabrication Equipment |
#3 |
Shane, your car looks great, and when I see you around this summer, you will be easy to pick out! have a great oil and gas day, Gary
I am usually relatively happy------Gary ![]() |
#4 |
Yes, unless they added an automatic advance. When you move the left steering column lever, does the rod attached to the distributer move? If so, then make sure you lift for starting, drop for running. The reason for it is it will kick back when starting and break your starter drive.
#5 | |
![]() Quote:
#6 |
They are sold by the Model A parts companies and , while not many pages, contain needed info. Read what Ford said regarding the operation of your car. Marc |
#7 |
ARCO regular. Valvoline 30W.
#8 |
If it says "Gasoline" on the pump - Run it.
If it says "Oil" on the can - Run it. You aren't running a 1000hp v8 here at 12:1 compression. You are running a 40hp flathead 4 at 4:1 compression. Best of luck to you.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
#9 |
So true!! It's not complicated.
#10 | |
![]() Quote:
years ago I blew up both of my snowmobiles on a family vacation because I didn't ask questions. I would hate to look back on a blown up dream car and have my wife say....see? I told you that you should have asked someone. ![]()
#11 |
I read somewhere that in a pinch, you can actually run kerosene or diesel in these engines also. I wouldn't want to try it though.
#12 |
I have white walls on 2 1/2 of my old cars. Love 'em but they seem to collect the womens...
#13 | |
![]() Quote:
#14 |
#15 |
I too like white walls. Have them on my 29 std coupe and I know that is a no-no but------ who cares. If you like them, keep them. But you will find you need to get some cleaner and clean them more that you might clean black.
Nice looking car and looks like you have a good helper. Have fun!
Fred Kroon 1929 Std Coupe 1929 Huckster |
#16 |
The thing about whitewalls is if you did trade your new factory tires at the dealer, the whitewalls of the day were double sided. Of interesting note is the appearance of the double sided whitewalls in many of Ford's original advertising art for the Model A's.
I like white walls, even the single sided ones, as I'm not out to impress anyone I run over. For the 'must be blackwall' purists, you can point out that NO Model A's came from the factory with a spare tire! Only a spare steel wheel. You had to buy the tire, tube, and valve stem hardware as an accessory from the dealer. So much for 'as it came from the factory'. ![]() Last edited by MikeK; 03-11-2014 at 10:17 PM. |
