Old 07-19-2013, 04:02 PM   #21
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: model a frame painting
Originally Posted by Rock Hornbuckle View Post
To test how tough it was. I coated a drinking glass then hit the glass with a hammer, the glass cracked, but did not shatter.
Rock, we could coat our droplight bulbs for safety
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-19-2013, 04:11 PM   #22
Bob/Kansas City
Bob/Kansas City's Avatar
POR also has their "chassis coat black" available in rattle cans as well as quarts, gallons etc. They say to apply over POR 15 but can be applied directly to bare metal but you will not get the same results.
For a budget job that looks good Rustoleum applied carefully will give good results and hold up well.
Bob/Kansas City is offline   Reply With Quote
Old 07-19-2013, 05:27 PM   #23
H. L. Chauvin
Hi reggiedog,
Might add to have utmost respect for those who do not see a need for rust encapsulation protection.
If one does not recognize any benefits from using it, gladly skip it.
It is far more time consuming to prepare surfaces for POR 15 & more work to apply multiple coats of POR 15 products.
Besides, it is always a joy to work with what one feels comfortable with rather than having doubts about a product -- each to his own.
H. L. Chauvin is offline   Reply With Quote
Old 07-19-2013, 09:34 PM   #24
SeaSlugs
SeaSlugs's Avatar
this is true - if someone has found a product or idea or method that works for them and makes them satisfied with the result then it works for them and should keep doing it and sharing his/her ideas even if someone else doesnt like it.
BUT dont forget you never stop learning no matter how old you get so its important to try new things once in awhile and listen to what others have found. While yea sometimes it doesn't work as well as what someone else has been doing in the past its important to keep an open mind about methods and products and give em a shot if it sounds reasonable.
And yes i aint that old but ive seen plenty of snake oil salesmen out there so thats when its time to ask questions.
TO me sometimes these opinion questions can be compared to what brand of beer do you like? Some say Old Milwaukee some say BudLight and wouldn't touch Old Milwaukee and vice versa. But if Ive never had an Old Milwaukee I'm willing to try it as maybe i DO like it and everyone else doesn't.
Like POR-15. I love the stuff! I do see how it is a pain to remove and its more of a glue than anything but for what i use it for and when i use it its amazing stuff, i cant say much about chassis saver or any other product (except rustoleum - does work for engine parts and stuff you want to remove later but for frame and axle stuff id go with por 15) as i haven't first hand experienced it.
anyhow someone can have my soapbox now....
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-19-2013, 11:13 PM   #25
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Mine was done in the early 80's with rustoleum primer and black no problems so far.
Old 07-19-2013, 11:21 PM   #26
Gunmetal blue2
Gunmetal blue2's Avatar
yes I have and it worked great. don't scrash
Gunmetal blue2 is offline   Reply With Quote
Old 07-20-2013, 05:50 AM   #27
reggiedog
reggiedog's Avatar
HI: Now that I have a lot of idea's ????. And a lot of them very helpful and some not so much. And some of them I have had used before myself and some never have even heard of. And I know some of them are very good Idea's and some not so good but now that I'm more confused then I was before as to what to put on the frame I just don't know as to what to do. But now I have a lot of Idea's as to what to do and NOT to do. I'm kind of between the POR 15 and the Chassis saver by Magnet and I did look on there web site and they do have a lot of paint to chose from. And I did go on POR 15's web site and they have about the same type's of paint that C.Saver has. But if I did go with any of the paints POR 15 or the C.Saver I would still have to buy more paint to top coat it with. So I when to eastwood's site and I talked to one of there tec's and what there told me is that they never had anyone ask that before and didn't have a clue to what to do. They of coarse recommended there paint of coarse so here's what I'm going to do I'm going to site here on the computer this weekend and look at both POR 15 and the Chassis Saver and the Eastwoods 3X Extreme chassis black for a top coat over POR 15 or the Chassis Saver. Or maybe I should just say the hell with it and just go with primmer and regular paint Just don't know but I will figure it out now that I have a lot of Idea's to go with. Thank's guy's reggiedog
reggiedog is offline   Reply With Quote
Old 07-20-2013, 09:03 AM   #28
Pinstripe
Reggie, What product you use depends a lot on how you prep the frame. If you will mediablast it for almost complete rust removal, then I think the eastwood epoxy primer and the ceramic chassi black is a very good way to go. If you are going to sand and wire brush, then the Por-15 or similar would be a better choice because of the residual rust. That's what they are for.The areas that cannot be reached by any rust removal methods( all the overlapped joints) are where I use rust encapsulator by brush to try and work into the joint. Just my thoughts. Tom
Pinstripe is offline   Reply With Quote
Old 07-20-2013, 09:27 AM   #29
Brian in Wheeling
Brian in Wheeling's Avatar
Sandblast, prime with an epoxy primer of your choice, then Rustoleum Satin Black. Looks great and easy to touch up if ever needed. I've been very pleased with this combo on several different car restorations over the years.
Brian in Wheeling is offline   Reply With Quote
Old 07-20-2013, 11:09 AM   #30
Terry, NJ
Terry, NJ's Avatar
Reggie, I guess by now you think I own stock in Magnet Paint, I don't! The description of what you go through with the pitfalls of POR 15 + plus the extra money, are enough to make me shy away from it. With C.S. there's no mixing, maybe just a little thinning. As far as a topcoat, Why not get your fender paint, $40-60@ Gal. from them too and kill two birds.... I don't know where you are, but there may be a dealer near by that you can discuss it with and he may be able to even show you a job or two and you can decide on whether it's for you or not. Check their website for dealer locations. There's at least six dealers near me in Pa. But I just made a suggestion and I won't feel brokenhearted if you choose something else.
Good Luck with it!
Terry
Terry, NJ is offline   Reply With Quote
