Old 07-03-2013, 08:15 AM   #21
Rowdy
Default Re: Boring a 125ci AF motor to a 200ci A motor
I can not post a link of the previous discussion of my block at this time due to the factI have not mastered cut and paste from my I-phone. Do an advanced search and likely you will easily find it minus Vince's comments. Yes there is a pic of the number stamp pad. If I remember my camera today I will get more pic's. I have no real explaination of why it is std bore, just know where I bought it and its history stateside. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 07-03-2013, 11:03 AM   #22
Jim Huseby
Jim Huseby's Avatar
Was the c.i.d. of the AF really 125? What was its BHP? How high, compared to the 200.5, would it rev? Was it also de-stroked? What did the Limeys do to hop it up? What were its performance specs when hopped up? Did it use standard 1.5" valves? Were the ports the same (about 1 3/8") ?
Jim Huseby is offline   Reply With Quote
Old 07-03-2013, 12:35 PM   #23
d.j. moordigian
d.j. moordigian's Avatar
Doing a quick calculation with a "stock" stroke the bore is right at 3.060".
d.j. moordigian is offline   Reply With Quote
Old 07-03-2013, 03:10 PM   #24
johnbuckley
johnbuckley's Avatar
According to one of "our" manuals : bore 3.0552 ,capacity 2043cc=124.6ci. stroke same at 4.25". ring gaps corresponding slightly tighter. Other differences with the 2043cc engine were in the smaller jets and venturi size, and a slightly smaller bore of inlet manifold. As far as I know there were no changes to valvesor cam shaft. To compensate for the lack of grunt the back axle was 4.55:1 . Also the cylinder head was different to give a smaller volume. Have no performance specs, but when in convoy the 2043cc cars keep up OK until it comes to hills . Limeys rarely souped them up at that time; they has Austin 7s to play with. All this research has got me scabbling through old books - Rowdy- I'm wondering if the authorities I've beeen consulting are wrong and that some 3.3 litre engines destined for RHD vehicles were in fact designated AF after all!!
johnbuckley is offline   Reply With Quote
Old 07-03-2013, 03:41 PM   #25
quickchange
quickchange's Avatar
I have two B small bore engines here in NZ , Although big end journal the same as big bore the rods are narrower at piston end, Head studs & valves are in a differant location along with the spark plugs, ONLY the crank is the same as big bore , Probally as much power as an austin 7 ???
quickchange is offline   Reply With Quote
Old 07-03-2013, 09:44 PM   #26
Rowdy
It never was in England as has been discussed before. Please take the time to read ALL of which Vince's research has revealed and not assume all AF engines were made in England.
http://www.fordgarage.com/pages/ABenginenumbers.htm
Old 07-04-2013, 12:01 AM   #27
Tudortomnz
Tudortomnz's Avatar
The Model A ''small bores'' were specific to countries that had horse power taxes on private vehicles. This was mainly Britain, France & some other European countries.
Australia , New Zealand & Sth Africa had no added tax on engine size, so no small bores. But, from 1932 Ford UK started to sell vehicles here as they were lobbying for preferential market access in British Dominions ; the small bore B4 became available in small numbers.
Little known was that Ford Canada offered the small bore option & they were sold in Singapore in the Model A era which may have had HP tax. It is likely they used the English produced engine as there was a production connection between Ford Canada & Ford Britain.
AF stamped blocks are not small bore specific. These are known on some Model A sold in Sth America which are US produced RHD cars with the standard size engine.
AF can be any part of a Model A vehicle sold outside the US.
Tudortomnz is offline   Reply With Quote
Old 07-04-2013, 12:58 AM   #28
Hotrodfil
Hotrodfil's Avatar
Here's inside a BF for reference - you can see the small bores.
Hotrodfil is offline   Reply With Quote
Old 07-04-2013, 04:47 PM   #29
Rowdy
Here are the pic's. Rod
Old 07-05-2013, 12:23 AM   #30
Hotrodfil
Hotrodfil's Avatar
That's not a small bore AF casting that's for sure.
Old 07-05-2013, 01:05 AM   #31
Tudortomnz
Tudortomnz's Avatar
I think that engine block [ Rowdys photos] is from a Sth American car.
Canada did not use those letters, so not from DownUnder.
Old 07-05-2013, 09:17 AM   #32
Rowdy
As I said before it was likely made in South Africa. At some point it made its way to Australia, then to the US. The car was restored by a local guy and the engine was replaced with one that did not need a full rebuild. The person that restored it moved to Iowa sometime in the late 80's and passed away in the mid 90's. The cars current whereabouts are unknown from there. Rod
Old 07-05-2013, 02:13 PM   #33
johnbuckley
Agree with you absolutely Hotrodfil..That's not a small bore AF casting that's for sure. ..(#29).. now look at the Juggler's excellent photo (#10) for a small bore engine casting and note the land between 1 and 2, and 3 and 4. and compare it it a std bore casting which only has land between 2 and 3. Check out the number www.fordgarage.com and maybe consensus would agree it's a Rouge std bore for a RHD ( and thus likely export to a RHD country other than British Empire- one in South America perhaps?) PS did you have any RHD As in the home market USA? Sorted?
