#21 |
Pretty fugly patches. If I were required to put a 1" hole in the sheet metal and fill in it again, I think I'd use a hole saw and weld in the original piece. Then solder and file till invisible. That looks like shite.
#22 |
I agree with Farrell.
And, not only that, but you still can't sandblast the bottom where the holes are drilled, unless you have some kind of blaster that shoots backwards. I would never drill or cut open a tank. If it had enough rust to be a problem that couldn't be fixed by flushing and using the small tank filter, then I'd use molasses to derust the tank. My next choice would be to buy another tank. |
